All Things Mk5 => Mk5 General Area => Topic started by: gti turbo on February 07, 2010, 11:17:58 am
Title: Ticking noise.
Post by: gti turbo on February 07, 2010, 11:17:58 am
When sat at traffic lights yestarday i could hear a ticking noise from the engine sounded like tappets but not sure.
Was just wondering if this is normal.
If not anyone any idea what it could be? :scared:
Title: Re: Ticking noise.
Post by: WhiteGTI on February 07, 2010, 11:39:34 am
How is your oil level?
The GTI engine is pretty tappety sounding to be honest.
The noise you heard could also be the climate system vents moving around, they click and 'tap' all the time!
Post by: gti turbo on February 07, 2010, 12:48:47 pm
Oil level fine and with all fans switched off started the engine and was fine until warmed up then started tapping again, :confused: It sounds like a diesel.
Post by: BMX on February 08, 2010, 09:58:09 am
sounds like the cam chain and tensioner
Post by: ukdub on February 08, 2010, 06:01:46 pm
Sounds like it to me as well.
GTI Turbo, is you engine code AXX?
Post by: Sie on February 08, 2010, 06:16:03 pm
sorry for hijack but price do VW charge for fix on this??
Sie
Post by: gti turbo on February 08, 2010, 11:22:16 pm
How do i find engine code?
And how much to fix?
Post by: ukdub on February 17, 2010, 07:30:11 am
Easiest place to find is on your log book under 'Engine Number'
As for price, not 100% sure.  I know the parts required are less that £100 and the fitting I would guess at about 3-4 hours.  Mine has been like this for over 40k now, keep meaning to get it done though.  Should add that the noise hasn't got any worse in that time, but that doesnt mean its ok to leave.  Will pull my finger out soon and get it done  :grin: :happy2:
Post by: Sie on February 17, 2010, 08:43:02 pm
Can they not just tighten the tensioner? or has it gone like that because the chain has gone slack??
Sie
Post by: xxx_mojo_xxx on February 17, 2010, 09:14:20 pm
Its a belt, rather than a chain...right?  :confused:
Post by: Russ_leeds on February 17, 2010, 10:22:38 pm
yeah its a belt. i believe the new tsi engines have a chain, so is much stronger
Post by: tony_danza on February 17, 2010, 10:47:12 pm
Have you noticed a smell of almonds?
ACME written anywhere in the engine bay?
Did you buy it from someone called Wile E Cayote?
Post by: QD MBE on February 17, 2010, 10:48:47 pm
:signLOL: :signLOL: :signLOL:
Post by: ukdub on February 18, 2010, 07:27:22 am
Belt is on one side, the cam chain is on the other.  The chain is just between the two cams on the HPFP side of the engine. :happy2:
Post by: Sie on February 18, 2010, 07:13:30 pm
Thought it was, and my noise is coming from the chain side, hopefully they can sort it when it goes in for its next service.
Sie
Post by: Gene Hunt on February 18, 2010, 07:33:14 pm
........correct,had to have mine replaced.
Post by: Richn83 on February 24, 2010, 02:37:31 pm
Im pretty sure the, GTI engine CCTA - CBFA engine codes are fully chain driven, unless this PDF ive been reading is wrong?
[pdf]http://www.arinahnell.com/other/vw/tech/20tsi.pdf[/pdf]
Post by: Russ_leeds on February 24, 2010, 11:12:04 pm
yeah thats wat i was on about. i read sumwhere it was
Post by: ub7rm on February 25, 2010, 07:50:06 am
Thats the mk6 GTI engine.
Mk5 uses the EA113 family of engines and has a belt on the left and a chain on the right  :happy2:
Post by: Richn83 on February 25, 2010, 09:57:35 am
Hmmmm, your probably right, as most posts ive just searched for show AXX or BWA codes for the MK5 engines.  Yet the PDF full link http://www.arinahnell.com/other/vw/tech/20tsi.pdf (http://www.arinahnell.com/other/vw/tech/20tsi.pdf) (so its a bit bigger) only shows peak power as 200, not the 211 of the revised engine.
I had also used this to determine that the engine had a turbo cooling function, I have still been running the engine at idle for a minute or so after a spirited drive, but safe in the knowledge that if need be the car would protect itself.  So assuming you are right and this is the newer engine do the older ones still have the cooling bypass for the turbo?
Since my last post, had a further look on-line, and found this http://www.eb-bruehl.com/files/mtz_zylinderkurbelgehaeuse_engl.pdf (http://www.eb-bruehl.com/files/mtz_zylinderkurbelgehaeuse_engl.pdf) so the pdf above as ub7rm stated is the new EA888 crankcase as both balance shafts are integrated into the crankcase, where as the EA113 had the secondary balance shaft added on down-near the sump.
Does anyone have a link to a similar document on the EA113 engine I can geek on?  :jumping:
Post by: Richn83 on February 25, 2010, 10:44:46 am
Im about to answer my own question! and I know this has all got rather off topic but the link below is a similar document for the AXX or EA113 series engine, has some very interesting info in about turbo operations, forced cooling to stop carbonisation of turbine, and also duel fuel injection into the cylinders at cold start to warm up CAT, and pre-startup pressurisation of the fuel on opening the drivers door, to reduce engine start times.
All very geeky I know! :ashamed:
http://www.golfmkv.com/forums/golfgoodies/mk5golfengine.pdf (http://www.golfmkv.com/forums/golfgoodies/mk5golfengine.pdf)
