All Things Mk5 => Mk5 General Area => Topic started by: jaylufc17 on November 12, 2017, 06:39:40 pm
Installed my xenons today and have had this coded through vagcom.
All 6 bulbs (including indicators) work yet the light bulb sign is coming on the dash... confused :thinking:
When starting the car up, it does not come up on the highline MFD to say a bulb is blown yet the light is on the dash
Few people have mentioned could be due to LED D2S Bulbs being in there?? anyone had the same issue?
Was it coded as Xenons without shutters installed
he said coded xenons with shutters installed
I had that issue on someone's car and it ended up being because of that. Code it as Xenons without shutters, see if that gets rid
Yeah most likely the coding for the shutters. If you' don't have vcds, one of those OBD fault readers for your phone will tell you exactly what is causing it. It did for me anyway.
tried my obd reader and said no code... will try the coding
Seems to have worked guys got the guy to change it thanks!
Do you think it could be because the yellow wires have not been put into the ccm module?
