All Things Mk5 => Mk5 General Area => Topic started by: willni on December 31, 2017, 10:13:32 am
Hello,
I ordered xenon adapters from Kufatec and they arrived but they have an extra short wire on each which I'm not sure where it's meant to be tapped into, I know a long wire would go to the CECM but these are too short to go pretty much anywhere. They're the ones pictured in the link
https://www.kufatec.co.uk/shop/en/volkswagen/golf/golf-5-golf-5-plus-1k/xenon-hid-headlights-adapter-vw-golf-5
and you don't have the long wire at all?
weird - mine came with the long wire but I got mine off a private sale on ebay.
(https://i.ebayimg.com/images/i/181642225148-0-0/s-l140/p.jpg)
@Rossimac (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9750) nope no long wire at all, seems a bit strange. Really not that impressed with kufatec right now tbh
Guessing here but that might be the shutter wire...?
I think so but the shutter wire should connect to the CECM, which is the problem
RetroRaz should be able to help here, he's a wizard with these things
Worked it out they are meant to go to the CECM wires says A5 and D6 referring to the pins in the CECM, don't see how when they're 3 metres too short.
Yeah they're definitely to go to the CECM to get full beam from xenon lights. It's really worth it, so I'd make sure to get it done. Likely is that you'll just have to add to that wire, which sucks!
I've noticed the same with kufatec before where they make the wires too short. Ended up Soldering a wire to extend it.
Yes they are for the shutters to open and close on flashing
Sent from my SM-G955F using Tapatalk
So Will, I bought another set of xenons and therefore the adaptor from Germany for another Golf.
And the adaptor of course didn't come with the extension wire to route to the CECM.
(https://i.imgur.com/butSfWI.jpg)
(https://i.imgur.com/8nDvNS1.jpg)
Of course, the eBay advert showed them in their full glory... :confused: https://www.ebay.co.uk/itm/Xenon-Bi-Xenon-Scheinwerfer-Adapter-Kabelbaum-Kabel-SET-fur-VW-Golf-5-V/110724701304 (https://www.ebay.co.uk/itm/Xenon-Bi-Xenon-Scheinwerfer-Adapter-Kabelbaum-Kabel-SET-fur-VW-Golf-5-V/110724701304)
How did you fix in the end? Get some long wire, solder and then get a terminal for the other ends?
Email the seller and get them to send you the wires
Yeah I think I will - their advert (after a Google translate) says the wires are included in the sale.
