		All Things Mk5 => Mk5 General Area => Topic started by: andyiseddy02 on December 31, 2017, 11:00:51 am
				Does anybody know if GTi steering wheel will fit straight into a 2006 Passat? :driver:
				Should fit with no issues. But if you want MFSW to work you'll have to check the control module installed in your car and maybe replace it with highline version:
 http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
 That is only needed if your Passat doesn't have MFSW now.
				Yes :jumpmove: we have MFSW.
 I would have to try one to see how much it blocked the view of the clocks but at least it is doable. (Is that a word) Do able.
