All Things Mk5 => Mk5 General Area => Topic started by: Assad on January 12, 2018, 10:58:44 am
Title: Best DV - Dump Value
Post by: Assad on January 12, 2018, 10:58:44 am
Fancy installing a dump value on my ED30 which is running a stage 2+ whats the best onces out there dont want something that sounds chavy...
Title: Re: Best DV - Dump Value
Post by: pudding on January 12, 2018, 11:57:08 am
OEM is all you need, or GFB DV+.
Post by: MIJ_JAGGER on January 12, 2018, 12:21:26 pm
I found a forge spacer bov thingy in the boot when I got the motor, stuck it on then took it off sharpish, very loud psshhhhhh, no thanks
Post by: Assad on January 12, 2018, 12:21:43 pm
Do the golf ed30 come with BOV standard?
Post by: Dan_FR on January 12, 2018, 01:18:56 pm
They come as standard with a recirculation valve, which is all you need. Makes plenty of noise with an open cone style intake, especially once remapped.
Do not fit any kind of vent to atmosphere type valve
Post by: Shoduchi on January 12, 2018, 02:15:40 pm
GFB DV+. I do need to check how mine is doing after 2 years of use. No issues with it so far.
Post by: Bodyboarder81 on January 12, 2018, 03:58:38 pm
What’s the Symptoms of a faulty one? What do I check ?
Post by: MIJ_JAGGER on January 12, 2018, 04:56:47 pm
Best thing to do is just check the dv itself for tears in the rubber diaphragm.
Easy enough to remove, much easier on an eddy
Post by: pudding on January 12, 2018, 05:40:44 pm
Lack of top end power, spikey inconsistent boost delivery and under boost fault codes.
