All Things Mk5 => Mk5 General Area => Topic started by: Bodyboarder81 on January 13, 2018, 12:25:36 pm
Title: Random exhaust pop ?
Post by: Bodyboarder81 on January 13, 2018, 12:25:36 pm
Hi all ,
I’m getting a random exhaust pop every now and then . Seems to be once the cars up to temp and just done it once on a 30 min drive . I’m running a full milltek turbo back non res system . The plugs were done 3k ago .... coil pack going? Drives fine and no lights ect
What’s people’s thoughts ?
Thanks  :happy2:
Title: Re: Random exhaust pop ?
Post by: pudding on January 13, 2018, 06:36:39 pm
Misfire.  If not spark related, probably a lazy injector.
Post by: Bodyboarder81 on January 13, 2018, 06:51:42 pm
Would that put a code on the ecu telling me what cylinder it is ?
I did possible suspect a injector also .... already bought some injector cleaner to run through but not expecting it to do much
Post by: pudding on January 13, 2018, 06:54:09 pm
Only if it's a persistent misfire.  Occasional popping won't be fault coded.  Mine started doing that a couple of years ago and then eventually it got to the point where the ECU flagged a misfire on cylinder 3.  Injector was on it's way out.
Post by: Bodyboarder81 on January 13, 2018, 06:57:26 pm
I’ll just keep an ear out then .... really is like once every 30-40 miles at the moment. It’s due a service in March so I’ll ask Jkm to look at it when they do the service , fit Loba, stage2+ it  :happy2:
Post by: GTi-Tecnix on January 16, 2018, 08:05:03 pm
Yes agree here - an injector  misfire. Mine did the same at idle after parking up for 10mins.
