All Things Mk5 => Mk5 General Area => Topic started by: norman1979 on February 09, 2018, 02:20:27 pm
Title: Coolant Fault Codes
Post by: norman1979 on February 09, 2018, 02:20:27 pm
I have two fault codes which are turning my EML light on:
P2600 Coolant Pump Control Circuit: Open
p2185 Engine Coolant Temp Sensor on Radiator Outlet - Signal too high
Does anybody know if these are linked error codes? I know where the temp sensor is, but where is the Coolant Pump sensor?
Title: Re: Coolant Fault Codes
Post by: pudding on February 09, 2018, 04:02:21 pm
I think the engine ECU toggles a relay for the electric water pump, so it might be complaining about that circuit.   Check to see if you get 12V at the pump connector.
