All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Jimes256 on March 11, 2018, 08:30:11 am
Title: Which engine code?
Post by: Jimes256 on March 11, 2018, 08:30:11 am
Hi all newb here. Hoping someone can tell me the best block to use for big power tune? I believe some have cross bolted main caps? Currently have cdl with circa 500hp and want to build a spare race engine. Also can we get apr flowed heads here or are they stateside only? Thanks
Title: Re: Which engine code?
Post by: pudding on March 12, 2018, 10:12:10 am
Any of the K04 EA113 engines.  BYD Edition 30, CDL S3, Cupra R, MK6 R etc etc
Awesome GTI are APR importers so could probably get the heads.
Post by: Jimes256 on March 14, 2018, 08:53:36 pm
Thanks. So do all of those have cross bolted mains? And what’s main differences?
Post by: pudding on March 15, 2018, 02:17:42 pm
Yes 4 bolt mains plus bigger wrist pins, stronger cylinder head material, more lift on the HPPF cam lobe, stronger and lower compression pistons etc etc.
A lot of differences for just 30-60hp more than a GTI.
Post by: Jimes256 on March 16, 2018, 02:19:33 pm
We have ie head and will only be keeping the crank and just want to know codes of the best block to buy?!
Post by: Teutonic_Tamer on June 06, 2018, 08:44:37 pm
Not correct.  It is only the S3 CDL engines which have a beefed up block, crank and bottom end.  The BYD shares an identical bottom end with the BWA and AXX, and even the 150PS non-turbo 2.0 FSI.
I have previously done considerable research on this very subject, and dispelled many unproven myths that the Ed30 shared the same bottom end as the S3.  It was published in detail on the Golf GTI UK forum.  My diligent research was subsequently confirmed by Volkswagen Motorsport Germany - their published specifications to race teams categorically instructed them to only use the CDL engine, even in the Cupra Cup cars.  They specifically prohibited the Cupra R and Ed30 engines for any competition usage.  Their reason was that the S3 block was cast from a higher strength alloy, and this was NOT shared with any other EA113 2.0 TFSI engines.
Post by: pudding on June 07, 2018, 12:29:26 pm
So the *1 footnote for the BYD engine is all lies then?   I've seen this written in several sources online and I would prefer to believe that than your 'considerable and diligent research'.
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjp9N2-uMHbAhVsIMAKHVehAZYQFghAMAI&url=https%3A%2F%2Fwww.my-gti.com%2F1046%2Fdifferences-between-the-gti-mark-v-and-mark-vi-engine&usg=AOvVaw1NSR2cre9nRRy_rUfXIQ-H
Post by: Shoduchi on June 07, 2018, 01:16:50 pm
That was the information shared by VW when the Ed. 30 was released in the market. :thinking:
Post by: GitFlog on June 07, 2018, 05:02:43 pm
How come this says they both run ko3 turbos? i thought the eddys and so on ran a ko4? and it was just the early gtis that had ko3's?
Please correct me if i am wrong this is a subject i am not really any good on and can only go on what i have read and been told  :happy2:
Post by: colesey on June 07, 2018, 05:38:12 pm
Note 1 refers to larger turbo for ed30 / byd etc
Post by: GitFlog on June 07, 2018, 07:33:31 pm
Note 1 sorry if i am being dumb not to sure what you mean
Post by: pudding on June 08, 2018, 11:06:37 am
From the site mate......
169 kW (230 PS), 300 Nm from 2,250 to 5,200 rpm (Edition 30, Pirelli)
BYD *1
*1 these versions have stronger pistons pins and new rings, reinforced connecting rods, new bearings, reinforced cylinder block at the main-bearing pedestals and cap, new, lightweight aluminium-silicon alloy cylinder head for high temperature resistance and strength, adjusted exhaust camshaft timing, increased cross-section high-pressure injectors, 1.2 bar boost pressure turbocharger with larger turbine and compression rotor.
The only thing I would question there is the boost pressure.  I don't think BYDs run 1.2 bar.  Closer to 0.9 - 1 bar.
Post by: Shoduchi on June 08, 2018, 11:27:29 am
BYD *1
The BYD run with 1.2 bar of peak boost and 0,9 bar of stable boost on stock file. :smiley:
Post by: pudding on June 08, 2018, 11:32:57 am
Ah OK, thanks mate, I wasn't sure if VW quoted a spike or a held pressure  :happy2:
Post by: GitFlog on June 08, 2018, 11:39:18 am
ok thanks i just didnt see any mention of ko4, but now i understand thanks
