All Things Mk5 => Mk5 General Area => Topic started by: ali on April 03, 2018, 12:58:29 pm
Title: expert advice needed please
Post by: ali on April 03, 2018, 12:58:29 pm
hi i bought an 07 gti last week just had the cam belt and service done as far as i can tell she runs and sounds fine it is totally original no mods at all,  has part service history and 113k on clock.    I have been advised to change the cam follower  o ring  (whatever that is)  fuel filter and maybe the cam chain   dv  and air filter..  obviously this will cost quite a bit in a garage but was wondering if it is right that i will need to change these things to be on the safe side as dont want anything breaking..   the chain has never been replaced what i can tell from the service book
thanks
Title: Re: expert advice needed please
Post by: th3_f15t on April 03, 2018, 01:28:02 pm
In short, yes to all those bar the cam chain unless it's very audiable (i.e. rattling and making excessive noise). Head over to the how-to guides for all the information you'll ever need:
http://www.mk5golfgti.co.uk/forum/index.php/topic,52731.0.html
And welcome along. :happy2:
Post by: DavGTI on April 03, 2018, 01:51:47 pm
Cam follower with the O ring is about £45 all in from TPS and the Rev G Dv is a similar price. They are easy enough to do at home and shouldn’t take too long to do.
Post by: ali on April 03, 2018, 01:56:22 pm
thanks for these replys    i am thinking about getting the stage 1 map   which air intake filter will i require or is the standard one fine.   if dont need the chain doing will i need to do the chain tensioners
Post by: th3_f15t on April 04, 2018, 02:38:27 pm
Air filters - For stage 1 a stock one is OK, a decent panel filter will help low end torque which is better for driving around town. If you're after more power up the rev range then get a cold air intake kit instead.
You won't be able to do the chain tensions without doing the whole system, so if you want to do it for peace of mind then renew everything.
Post by: ali on April 04, 2018, 03:12:27 pm
cam belt done   water pump done   service done
getting done monday  Rev G  DV,   cam follower and o ring,  fuel filter,   new battery   and checking the chain as no noise etc from it at the moment.    At higher (4) 4 rmp car picks up great but under 4k not so good  any ideas how to improve low end low revs speed please
Post by: mk1mad on April 04, 2018, 03:33:24 pm
Get the new Dv fitted first and then see how it is.
Post by: ROH ECHT on April 05, 2018, 08:26:39 pm
The "cam follower o-ring" doesn't exist. Perhaps the person saying that originally meant cam follower and hpfp o-ring. When the hpfp is removed to replace the cam follower...there is an o-ring about the base of the hpfp where it goes into the cam chain tensioner cover. However, it isn't necessary to replace the o-ring unless you see oil seeping from the "hpfp to tensioner cover" connection.
Yes, the cam chain and tensioner aren't necessary until you hear a louder slapping inside the rear of the engine. When having to do those, you might as well replace the rings, these; https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/camshaft-adjuster-housing-seal-set/06f198107a/?gclid=CjwKEAjw5pKtBRCqpfPK5qXatWYSJABi5kTxAEu3Fro_PDcaoBk1JN-5rCM1m1FuG671w5eFAzatuRoCb3Pw_wcB, vacuum pump, and the N205...don't forget to clean the strainer screen at that time when doing the chain and tensioner.
Post by: ROH ECHT on April 05, 2018, 08:34:59 pm
Didn't mention your transmission, so if DSG, the fluid and filter needs service every 40k miles. The timing belt and water pump are at 80k miles iirc. I do mine at 60k miles. But most important is the cam follower as they are usually worn through by 120k miles.
Post by: ali on April 06, 2018, 10:44:04 am
thanks for all the advice,   it is the manual version not dsg
it does have gas conversion hid lights but they are playing up flashing  going on off etc and personally dont like driving with them at night so am taking them out and reverting back to the standard ones.
Post by: ali on April 06, 2018, 11:05:08 am
couple of other ones also please,   at the moment i am returning around 26  27 mpg  but dont do long trip is this about right.   car is totally standard no mods .     Also i am looking to get a new head unit was thinking the golf one with sat nav forgot the number think its rns510 or something like that.    will this be a standard fit or do i have to buy gps and dab ariel
