All Things Mk5 => How to Guides / Troubleshooting => Topic started by: chris2018 on May 24, 2018, 08:52:19 pm
Hi all
Had problem with the Climatronic system on my 04 golf GT only had the car a few weeks but its been working fine up to now
today had no recirculation when i press the recirculation button air was just stopping from the vents fans was still going full power.
if i put it in ECON mode (air con off) with recirculation off it was working but if put the Air Con back on (on a low temp setting) lost all air from the vents again.
Did reset and calibrate (HOLD ECON AND MID VENTS) buttons together do not know fully what does but after some you tube in it looks like it runs a diagnostics/calibration tests anyway its seems to be all be working again :congrats: not sure if it fixed for the long run thinking it could be sign that the Vent Flap Motor is on it way out...
what do you think
