		All Things Mk5 => Mk5 General Area => Topic started by: els904 on May 25, 2018, 10:42:29 am
				Could some kind person please have a look at their tailgate strut and tell me what the force rating is. I had mine replaced a while ago with non-OEM parts and it's very hard to close. They appear to be 550N and it would be useful to know what the original spec is.
 Peter
				Hi Peter
 Not sure what pressure they are but check the pic of my old ones ive fitted a popper kit so cant help with the ones fitted but will put a pic of my old OEM ones for you for if any help at all
 Kris
				Popper kit says 600n and arnt to bad to close stiff but ypu get used to it
 OEM 535N?? Standard in pic
 Tryed to get a pic of popper kit ones but writing to small for camera to pick up(https://uploads.tapatalk-cdn.com/20180525/c31c1c38727f1b7a93b9143a9164dfd3.jpg)
 Sent from my SM-G935F using Tapatalk
				Thanks for this - 535 isn't much less than 550 and VW ones are £50 each! I'll just have to eat more shredded wheat!
 Hahaha i am 6ft 4 so probs helps
				I have the hatch pop kit. It has the 600N struts. I know it is only supposed to pop the hatch open...but when warm it opens the hatch completely. So, my thinking is "would a 600+N strut open when not warm" and "has anyone found a 600+N replacement?". I am unaware of which auto the pop kit's struts come off of...but think that an aftermarket replacement may be 600N plus given there's a 550N replacement for the oem 535N strut.
				SGS make specific pressure struts In shiny metal too https://www.sgs-engineering.com/gas-struts/stainless
 Mine is the the same dude next to all the time it just pops the seal dosent open all the way unless the a flying pig flys past in the sky since ive had them fitted must have opened all the way twice!!!!!! Even the mrs said blooming hell its opened haha
				Right, mine only opens all of the way if it were sitting in the sun during the summer time.
 Poppers are set correctly and I actually just replaced them due to broken internal springs. But if I could find say a 625N to 650N strut...maybe they'd open more often. I know these use a Cupra strut ball cap but do not know which struts are used. I think I can find out running a rearch for the oem part number. Closing isn't an issue as I can usually close the hatch by grabbing the inner grab with one hand and pull it downward.
				Mine dosent do it hot or cold so i must have weak struts or springs when you find some bigger power ones let me know please dude
				I will...going to write down the oem number and search to hopefully find that one aftermarket, Fabi perhaps, makes a replacement strut with just a tad more lift.
				My pn; 6Y0-827-550-C-01S is a Febi-Bilstein item no; 31652
 All replacements for the above pn:, not limited to Febi, I found so far are 600N...but I will keep looking.
 Specs are:
 length: 440mm
 stroke: 170mm
 tube: 19mm
 rod: 8mm
 I found one for an Audi A6 pn: 4F9-827-552-D, having 650N but was 490mm length and stroke is 184mm. I will be relentless.  :drinking:
