All Things Mk5 => Mk5 General Area => Topic started by: Murray86 on February 10, 2010, 05:09:13 pm
Tryin to change battery my mk5 as we speak but cant see how the battery is held in place on the tray??
I have removed + and - but cant find whats holding battery??
Murray
remove the front section of the plastic cover, (two clips attach to the battery tray) then there is a 13mm bolt on the battery clamp, at right side of the battery. You will probably need an extension to reach it.
Hope this helps
