All Things Mk5 => Mk5 General Area => Topic started by: harveym3 on July 15, 2018, 10:16:10 pm
Hi all anyone know what this code means 049922 it's a gearbox fault for dsg
No one ?
Have you changed anything? As far as I can tell about that fault code it's:
049922 - Software Incompatibility with Transmission Control Module
So basically a coding problem.
The only thing I can think of is I fitted a different ecu to check it worked but I new it wouldn't run due to coding. Could it be that ? When you clear it the code just comes beck it's also saying the ecu isn't coded but it runs fine .
