All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: rubber toe on February 11, 2010, 09:37:08 pm
Title: mk6 gti steering wheel fitting advice
Post by: rubber toe on February 11, 2010, 09:37:08 pm
hi i've got a mk6 gti steering and was wandering if there was anything else i need to fit along with it ?
Any info much appreciated  :happy2:
By the way my car is a 2005 gti with midline dash  :happy2: :smiley:
Title: Re: mk6 gti steering wheel fitting advice
Post by: danishmkvgti on February 11, 2010, 09:51:19 pm
MFSW??   :wink:
Post by: rubber toe on February 11, 2010, 10:58:21 pm
forgot to say no mfsw  :ashamed:
Post by: JPC on February 11, 2010, 11:06:09 pm
Easy job mate!  Fits just like the mk5 one
Post by: rubber toe on February 11, 2010, 11:20:04 pm
cool thanks bud  :happy2:
Is it a case if just coding the mk6 mfsw in then or will the buttons not work because i didnt have a mfsw in the first place ?
Post by: vRStu on February 12, 2010, 06:15:31 am
You said above that is wasn't a MFSW _ I guess you got confused  :signLOL:
You may well need a new steering controller if you weren't MFSW originally.  I'm sure one of the guys who's fitted it will be along to help.
Post by: rubber toe on February 12, 2010, 07:42:40 am
confused - definately  :rolleye:
just assumed all the mk6 gti had mfsw because everyone i've seen has had it  :chicken:
Post by: SteveP on February 12, 2010, 07:51:23 am
Yes the Mk6 has MFSW as standard  :happy2:
Post by: danishmkvgti on February 12, 2010, 07:57:41 am
http://www.mk5golfgti.co.uk/forum/index.php?topic=10591.0
hm, then this is an odd offer  :laugh:  :wink:
Post by: SteveP on February 12, 2010, 08:14:20 am
I meant to say the Mk6 GTI has it as standard  :happy2:
Post by: ollie288 on February 12, 2010, 03:05:29 pm
When I changed to the mk6 MFSW (no MFSW before) I had to change to this:
1KO 953 549 CH ( i ordered the BK but it didn't work with the slip ring)
Also you will need the slip ring 1KO 959 653 C (your car may have it)
Ollie :happy2:
Post by: danishmkvgti on February 12, 2010, 03:25:53 pm
Ollie :happy2:
And if you have C/C you can expect to lose it as we haven't solved that problem yet  :sad1:
Post by: ollie288 on February 12, 2010, 04:09:39 pm
Ollie :happy2:
Ohh yeah and that!  :happy2:
Post by: rubber toe on February 12, 2010, 08:43:14 pm
sweet thanks a lot guys  :drinking: :happy2:
tho just found out that my steering wheel is back order  :sad1:
Post by: ollie288 on February 12, 2010, 10:17:56 pm
No probs.  :happy2:
Are you buying from the dealer?
Post by: rubber toe on February 12, 2010, 10:27:23 pm
yeah , i've already got the airbag so its just the steering wheel im waiting on  :party:
Post by: ollie288 on February 12, 2010, 10:34:46 pm
I bet that cost a fair chunk! Might not be to bad if you have the airbag though. You will love it when its fitted!  :happy2:
Post by: rubber toe on February 13, 2010, 01:45:43 am
wasnt too bad was 300 , bargain really for what m getting  :smiley:
Post by: stephen8512 on April 30, 2010, 04:11:44 am
The mk 6 C/C stalk has partnumber 1K0 953 513 G
I think u need this in order for the steering wheel to work
Can someone confirm if Steering coloumn controller partnumber 1K0 953 549 CH is compatible with the DSG flappy paddles? As I have a jetta TFSI with DSG and i want to use flappy paddles
Post by: illektronik on May 27, 2010, 06:40:30 am
Hi guys. Is there a DIY for this mod? That HPA Turbo R32 down here has one of these wheels and wants to fit it to his 2008 built MKV R32.
Basically it sounds like I just need to find the DIY to take off the MK5 and then fit the MK6.
Are the wiring and connections are the same? Is this slip ring an issue between the two models?
Cheers for any advice. J
Would he need to buy the 2010 Golf R or Scirocco R Steering Wheel Control Module. It's an R-Line wheel (Black trim, not silver)
Post by: stephen8512 on June 04, 2010, 06:53:28 pm
Hey John :)
AP already has the part numbers to get it to work but yeah to get this to work on MK5's I was told you need
1) steering column controller unit
2) "C" revision slip ring
3) MK6 Cruise control stalk
the steering column controller i'm assuming is the MK6 one. The only difference i Think between the R-Line and the normal GTI MK6 wheel is the black trim....
Post by: illektronik on June 05, 2010, 01:03:10 am
Stephen, Anthony has the numbers, because he asked me to look into it for him. I gave him what he needed last week thanks to MortyGTI (Darren).  :happy2:
Post by: stephen8512 on June 05, 2010, 07:41:02 am
Hahahaha ahh I see. Fair enough :) I too actually got the numbers from MortyGTI on the GolfMK5 forum   :grin:
Post by: TonyZed on June 09, 2010, 12:01:15 am
Ollie :happy2:
I had mine fitted today, a cruise control unit from Skoda Octavia works!! :jumpmove:
TonyZ
Post by: Andy on June 09, 2010, 09:09:36 am
Darren fitted a mk6 steering wheel to mine on sat..it looks excellent
http://www.mk5golfgti.co.uk/forum/index.php/topic,15463.msg226200.html#msg226200
Post by: stuupnorth on June 17, 2010, 09:33:43 pm
Hi guys
my gti dsg doesn't have mfsw but paddles
would i be right in thinking that the mk6 wheel with paddles but without mfsw
will be a straight swap??
Stu
Post by: Top Cat on June 17, 2010, 10:32:38 pm
Hi guys
Stu
You cannot get a MK6 DSG steering without multi- function.It comes as standard onDSG wheels, and it is not a straight swap you need a new controller unit as well.  :happy2:
Post by: stuupnorth on June 18, 2010, 06:51:33 pm
what about this
http://cgi.ebay.co.uk/GENUINE-STEERING-WHEEL-LENKRAD-VW-SCIROCCO-MK6-VI-DSG-/250652067663?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a5c07074f
Post by: Top Cat on June 21, 2010, 07:04:06 pm
what about this
Its not a GTI wheel but none the less, you are right. I wish i would have known this was available before i went through the whole 9 yards getting one. I could have bought that and got myself a couple of intakes with the change for what i have paid.  :sad1:  :rolleye:
Post by: stuupnorth on June 22, 2010, 06:49:51 pm
so what do you think
will it fit ok
Post by: .:GTI|SUNNY:. on September 13, 2010, 07:31:42 pm
Sorry to bump this thread, didnt see the point of making a new one
Just want some clarifications please
Just found this:
http://cgi.ebay.co.uk/VW-STEERING-WHEEL-GOLF-5-V-6-VI-R32-SCIROCCO-GTI-MK6-/110581994583?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19bf335457
I dont have MFSW at the moment and tbh i dont want the buttons, so is it just a simple case of taking my MK5 wheel off and put the MK6 one on?
Is the process:
disconnect battery and leave it for 5-10mins
Take MK5 wheel off
Plug the horn connection to MK6 wheel
bolt on the MK6 wheel
connect battery back up
Using same bolts
is this right? as i did a wheel swap on my previous car and did this process
Post by: N8KOW on September 25, 2010, 04:21:50 am
I've never disconnected the battery when fitting steering wheels to my A3 8P  :driver:
Post by: poko on September 25, 2010, 10:01:38 pm
i bought the mk6 wheel off of one of the many sellers now (mk6).
it appears that they are "falling" off of the ROCCO assambly line.
i got a new rocco R black trimmed wheel with the airbag , compeltly new for 300 pounds and he was willing to sell normal gti for 210.
the same price applies if you want MFSW or paddels.
Post by: GLIDN on November 03, 2010, 09:59:35 pm
Sorry to bring up an old thread,
I did search for a while to get the answers I was after. But this seems to be the most informative at this stage.
Just to clarify, There are no additional wiring looms required. Going from 05 mk5 GTi non MFSW (manual) to mk6 MFSW Steering wheel?
Simply, SW Controller, Slip ring and CC stalk from mk6?
I'm assuming there's some coding to be done the CAN-Gateway to let the car know you now have MFSW?
Otherwise just going to the mk5 MFSW I only need the controller? or will I need the slip ring too?
Post by: danishmkvgti on November 04, 2010, 10:52:51 am
if you buy a complete MFSW the inside wiring should be included. regarding slipring check what revision you have, if A or B it need replacing with minimum revision C for MFSW to work  :smiley:
Post by: danishmkvgti on October 14, 2011, 06:45:13 am
Any knowledgeable people there can confirm if this will work on a Touran along with a mk 6 MFSW and the steering angle sensor??
1K0953549AP
 :notworthy:
Or maybe this
1K0 953 549 CK
Or
1K0953549CQ
Post by: Eddie-NL on October 14, 2011, 06:55:26 am
If you want a mk6 wheel with buttons
use either
1K0 953 549CH or 1K0 953 549CK
I haven't used CK, but on ross-tech steering controller list it says it does support the G85
However I had a BS and CB and they were supposed to support G85 on the list but didn't
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Post by: danishmkvgti on October 14, 2011, 07:29:20 am
Thx Eddie,
I bought a mk 6 normal mfsw with both arms and controller controller did't support the steering angle sensor  :sad1:
Also do you know of any vehicles that does not support rear wiper function in the wiper arm?
The arm is fitted but wifey can't push it forward to activate the rear wiper??  :confused:
Post by: Eddie-NL on October 16, 2011, 08:01:06 pm
Thx Eddie,
Hi Jake
You probably have a CD version and the stalk came from a Jetta, Eos or Passat Saloon
So You would be best to get a CH controller and change the stalk to one ending with H or J
Post by: paulw123 on May 15, 2014, 11:02:38 am
Sorry to re-start this thread, but it has loads of info in it.
Iam toying with the idea of fitting a MK6 mfsw  to my 08 Mk5.
Currently it is mid-line ,non-mfsw, retro fitted with cruise in feb2012.
1)Is my slip ring ok?
2)do i still need control module 1K0 953 549CH?
3)do i need a new harness? like in this link?
http://www.ebay.co.uk/itm/OEM-STEERING-WHEEL-MODULE-1K0953549CH-AIRBAG-HARNESS-5K0971584-For-VW-GOLF-6-GTI-/301158581121?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item461e734381
4)is any coding required?
5)could i fit this myself, is there a guide?  i can't do coding......should be ok with mechanical stuff & good guide....bit worried about handling airbag.......
Post by: paulw123 on May 15, 2014, 05:39:33 pm
evening bump
Post by: fab5freddy on May 15, 2014, 07:06:33 pm
1)Is my slip ring ok? Scan with VCDS and check which version you have
2)do i still need control module 1K0 953 549CH? Yes
3)do i need a new harness? like in this link? Yes you will need airbag loom to support Multi function
4)is any coding required? Yes
5)could i fit this myself, is there a guide?  i can't do coding......should be ok with mechanical stuff & good guide....bit worried about handling airbag....... Yes  http://www.myturbodiesel.com/wiki/steering-wheel-mfsw-swap-and-paddle-shifter-retrofit-diy-for-mk5-vw/ (http://www.myturbodiesel.com/wiki/steering-wheel-mfsw-swap-and-paddle-shifter-retrofit-diy-for-mk5-vw/)
