General => Random Chat => Topic started by: Juliand on July 21, 2018, 10:42:21 am
Anyone know of anything up to the job......you know......when the freezer needs defrosting and someone yanks the drawers open and they crack by the pull handle, grrrr.
I can't see anything working due to the low temperature and the flexing, as you try to pull it open against any resistance. Really needs some kind of re-inforcement, or plating somehow to add some strength. Got me baffled. Shyte really - it's happened on every freezer we've had - or maybe we just don't defrost often enough - always something else to do; trying to get it empty; finding somewhere for what's left in it; then water all over the kitchen floor - nightmare!
Cheers for any thoughts :thinking:
tiger seal any good?
I have same issue!.
Buy a small piece of perspex from eBay, and stick it to the back side of the crack using weatherproof sealant - I'm looking at sikaflex 512 caravan, which looks to be good for -60!
Areldite epoxy, very strong and suitable for temperatures as low as -30 degrees Celsius. :happy2:
Time to jump into the 21st century with frost free Go on splash out the GTI upgrades can wait :signLOL: :signLOL:
Thanks for all the suggestions chaps......
It really needed some reinforcement, so I had a nose around the garage and used a small piece of wood and cut it down (1cm X 10cm, roughly) so that it fitted quite snuggly into the recessed handle part of the drawer, where it had cracked right in the middle. This gave sufficient support / strengthening, but looked awful, so I covered the wood with 3M's self adhesive metal repair tape, which has a chrome finish, which also helped to secure it to the plastic drawer handle.
It looked pretty good, and functions fine - wifey say's its good, and she's very fussy. So far, so good, been on a while now, but time will tell if it holds out..... Beats over £30 for a new drawer, just a bit of time and effort, ha ha
