All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: oak_grun on July 31, 2018, 08:50:05 pm
Title: What to replace when subframe is off etc...
Post by: oak_grun on July 31, 2018, 08:50:05 pm
Hi, I will be doing a overhaul of components on my Edition 30 shortly and would like some advice from people who have done something similar recently in terms of what I should replace whilst doing other bits and pieces etc...
So I will be replacing the following bits;
Engine mounts for Vibratechnics - full set including subframe mount
H&R Arbs
Anti Lift kit
H&R springs on standard shocks for now...unless I can get my hands on a set of Bilstein shocks in time...
Whilst the above is being fitted, is there anything else I should consider replacing at the same time?
Thanks in advance. :happy2:
Title: Re: What to replace when subframe is off etc...
Post by: bobby_fodge on July 31, 2018, 10:49:28 pm
check there is no play in the rack. Could take off the downpipe and not knock out the pre cat whilst the subframe if off.
could fit a deadset kit or fit the ecs shims with Passat bolts.
Post by: MIJ_JAGGER on August 01, 2018, 12:30:22 am
Probably goes without saying, replace all bolts with new
Post by: oak_grun on August 01, 2018, 11:37:43 am
New stretch bolts will be used on engine mounts  :happy2:
Anything else?
I think I've read some where that when fitting anti lift kit, it's worth changing bottom arm bushes too?
Post by: pudding on August 17, 2018, 08:42:36 am
You'll be needing a full set of subframe bolts as well as the engine mount bolts.  Everything that supports the drivetrain and chassis components uses stretch bolts.
I wouldn't bother with the front wishbone bushes personally, but the rear ones (ALK) is well worth doing.
Tyrolsport deadset is well worth doing.
Also a good time to check for split CV boots and other maintenance items.
