All Things Mk5 => Modifications & Technical Area => FAQ's => Topic started by: Jimbo2802 on August 05, 2018, 05:30:47 pm
Hello i am after the part number for the fuel return pipe from the fuel filter to the fuel tank as the clips bust :confused:
Its the pipe that goes to the middle nozzle on the in side of the filter if that makes sense. The pipe with the blue tag
Tried looking everywhere for the code but im struggling
Car is a 54 plate gti. AXX engine
James
You should post in the general area. Some sub forums rarely get looked at.
Instead of replacing the whole line, replace the broken fitting. https://www.connect-consumables.co.uk/products/Hosing_Tubing/Fuel-Pipe-Connectors-$-Hose
Just need a heat gun and a stanley blade.
