All Things Mk5 => Mk5 General Area => Topic started by: DeWet on October 06, 2018, 07:25:39 am
Title: AWD gearbox options
Post by: DeWet on October 06, 2018, 07:25:39 am
With my BWA engine conversion finally done I'm now looking to do my AWD conversion. I know its a lot of eork and thr gains might be little compared to a properly setup FWD but its a nice challenge for me ;)
Someone told me that the mk1 TT box will bolt straight on but I'm also trying to find out if the mk6 R manual box will fit.
The code is KZV and the newer gear ratios and diff must be better than the TT box?
Can anyone shed more light on this for me?(https://uploads.tapatalk-cdn.com/20181006/d3ab9e72b7bc2f989143f3fc8c872404.jpg)
Sent from my SM-N920I using Tapatalk
Title: Re: AWD gearbox options
Post by: pudding on October 06, 2018, 01:23:37 pm
Golf 6R, 8P S3 or TT-S manual boxes will all fit.
Post by: DeWet on October 07, 2018, 02:57:24 am
Great thanks.....is there much difference between their gear ratios and transfer cases?
Post by: DeWet on October 15, 2018, 06:19:32 am
I found a manual S3 box. Would I need to replace flywheel and clutch to fit or will it work with stock gti flywheel and clutch?
Post by: DeWet on October 17, 2018, 11:19:43 am
My BLX engine config seems to be running the 228mm diameter clutch unlike BWA's 240 which should be the same as the S3 :(
So will try and find flywheel and clutch for this and hope it fits my crankshaft
Any idea if I need different driveshaft on the transfer case's side?
