All Things Mk5 => Mk5 General Area => Topic started by: Northern_ED30 on March 09, 2019, 10:57:50 am
My rear left fog light is not working! After doing some googling I think it’s because my canbus is coded for left hand drive, I don’t have vcds, I’ve Been doing the long coding using obdeleven.
I’ve read that it’s in byte 9 of the long code, but my new canbus only has bytes 0,1 and 2. Any idea what I need to do to tell the car it is a RHD model? Thanks
I repaired the one on my sons car. It was a physical problem rather than a coding problem.
I think it is a common fault. It was a broken wire in the rubber boot from the boot lid to the body. I had to slice the rubber, fix the wire and tape up the rubber boot.
