All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Pissat4motion on May 14, 2019, 05:19:26 am
Title: Fault after cluster swap
Post by: Pissat4motion on May 14, 2019, 05:19:26 am
I've got one code after the swap and the abs lights on the dash. From what I've read I have a compatible abs module. I'm assuming theirs a basic setting/adaptation/ coding I haven't done.
Anyone with some insight?(https://uploads.tapatalk-cdn.com/20190514/b6a2fcee942c3669d0e48e0acd5884f8.jpg)(https://uploads.tapatalk-cdn.com/20190514/fd4c859c13ad2825ec2a57aa0610a414.jpg)
Sent from my Nexus 6 using Tapatalk
Title: Re: Fault after cluster swap
Post by: ady-uk on May 14, 2019, 05:17:21 pm
going by your name, that pump is NOT 4motion compatible.  'AC' Will never accept 4mo coding.
Have you updated ABS pump too?
Post by: Pissat4motion on May 14, 2019, 05:31:12 pm
Old name from a previous car lol
It's an 07 GTI. Pump is original which is one reason it's confusing why that's the fault I'm getting
Post by: Janno2G on September 29, 2025, 07:58:09 pm
I have the same issue after changing my cluster to full fis. Did you ever get this sorted?
Post by: JamieSmeatonVW on January 30, 2026, 10:47:44 pm
Any luck?
