All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Howardvwgolf on February 23, 2010, 09:18:33 pm
earlier my numberplate lights started playing up. I got home, opened the boot for something and the lights were on, then i got back in the car to move into the garage and the light out warning was on, when i got back out to have a look they werent working. So i turned the lights off and then on again, walked round the back and they were on and then a split second later went off again. Now they wont come on at all!! :scared:
Ive had them on a while now and not had any previous problems, any idea what the problem might be?
Did you buy them off ebay?
yeah
I got some of ebay (I will try and find the link) and they failed in under 2 months. Emailed the seller and he said they are having problems with the mk5 golf and some audis and refunded my money. Might be worth contacted them. :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,10114.0.html (http://www.mk5golfgti.co.uk/forum/index.php/topic,10114.0.html)
The ones linked in the first post. :happy2:
Theyre the ones i bought!!what have you got instead now then? have they simply blown and thats why they arent working?
I believe so he said they are having problems with the life of them on the mk5's and some audis. I sent them back and he gave a full refund. I just put the standard ones back in for now. :happy2:
ok then mate, thanks alot for your help :happy2:
can anybody recommend me so some bulbs which are likely to last longer?
I had a similar problem when i had my fabia. got 3 led festoon bulbs from autobulbs direct and they failed within 3 months, told there was a problem with the voltage or current or something being wrong for them so went back to standard bulbs
ive got some that look like those but they have ridges on the back, had them for well over a year with no problems. cant remember where i got them from though, they were about £25.
Ok so I recently fitted the LED numberplate lights that were advised about on here off Matt
However one light has gone out.. so thinking a bulb was fubared I ordered some new ones, however turns out its not the bulbs :rolleye: :rolleye:
So Ive taken the holders out and switched them over and discovered it seems to be a faulty holder.. However what could be faulty with the holder!? Its only 2 pieces of metal!?! :fighting:
Rub the contact metal surface with a bit sandpaper & spray with contact cleaner if you have it, squeeze the contacts so they're closer together so you may get a better snug connection with the different sized festoon that's in
