All Things Mk5 => How to Guides / Troubleshooting => Topic started by: dave1814 on July 24, 2019, 08:59:43 am
Hi,
So the other day PRNDS started flashing on dash and the S is lit up on the gear selector, ive read the error codes and got 3 relating to the issue (I think!)...
Address 02: Auto Trans Labels: 02E-927-770.clb
00194 - Ignition Key Removal Lock
008 - Implausible Signal - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
2 Faults Found:
009 - Open or Short to Ground - Intermittent
02413 - Switch for Selector Lever Position P Lock (F319)
However gear shifting seems fine in D, S and using the flappy paddles.
From what i've read im thinking it could be the selector mechanism?
Any ideas?
thanks!
Bump.
Anyone any ideas?
Thanks!
As in the mechatronic but your driving fine in every gear could be a tricky one
Sent from my SM-G935F using Tapatalk
I've just tried running a DSG reset but thats not helped.
One thing I did notice was this....
(https://i.ibb.co/17nK2pd/vcds-measuring-blocks.jpg)
Is it normal to display 'D' in selected gear when 'S' is actually selected?
thanks!
Dave
Do these have the same gubbins as on an a4 selector wise? My mate had the ‘red light’ selector issue and that pointed to the circuit board. However the magnet had also moved so using a shim on that, it’s actually cured the problem.
