All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Bad-vw-boy on September 01, 2019, 10:19:40 am
I have a 2007 vw golf gti what size are the front discs are they 280mm , 300mm or 312mm..as I cant seem to find a guide advising of this...also looking to put a upgraded drilled disc as a replacement any recommendations on manufacturer, and pads..ebc, Brembo etc?
Pretty sure they’re 312 mate.
Yes should be 312mm front 286mm rear
Im using mtec grooved.There good because I have porsche pistons :happy2: Best discs Ive had were EBC with textar and pagid pads :happy2: The EBC must be close to £200/axle. There must be deals for pad and disc combo
Am using mtec c hook with endless mx72 pads. Awesome performers and streets ahead of the EBC redstuff I tried before. The latter weren’t bad - had good bite with some heat in them / quiet / low dust - but the MX72 are superb. Also use steel hoses / bronze caliper bushes / ATE 200.
I was looking at some Brembo xtra peforated and vented £120 for the pair but not sure what pads...has any one used these discs
The rear fog light is not intended to be a "4th brake light", it should be wired to the front fogs or a dedicated switch. Write-up is good but it would make more sense to have the rear fog light as a functional modification.
