All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: BadBazGti on October 02, 2019, 10:54:52 pm
Hi Everyone .. can someone help me ???
I have a 2007 manual GTI Edition 30 ....
With Midline Dash And Non MFSW ...
I am About to Buy A MFSW from another Edition30 .....
I know I need a different steering control module .... and new Mfsw Airbag wiring harness .... And will need to code it in ....
Question is Can Anyone Give me the part numbers for
1 .. The Steering control module ..
2.... The MFSW Airbag Wiring harness ...
And also the VCDS Coding procedure???
Thanks in Advance for Any help ....
Regards
Baz
Sent from my SM-G960F using Tapatalk
Steering module should be same partnumber as your current just with index "CH" and then you need to change your cruise control stalk to index "G".
