All Things Mk5 => Mk5 General Area => Topic started by: RobC on October 11, 2019, 12:41:21 pm
Title: Wheels pushed forward due to Anti Lift Kit
Post by: RobC on October 11, 2019, 12:41:21 pm
Hi guys,
Ive done a search but can only find one post on this. I've just had the Powerflex ALK fitted and its shunted the wheels forward. Due to the 19" wheels Im running and the ET required to clear the Cayenne calipers this has now caused it to rub and so I've had to raise it up. I read a post suggesting the same thing happened to another Forum user but this was using the Whiteline kit.
They seemed to suggest that the AL is achieved by changing the offset of the console which shifts the subframe forward. However people were recommending SuperPro bushes and said their system is different as they off centre the bush which is how theirs achieve the AL. My question is, if I fit the SuperPro ALK with the console & bushes, will this return the wheels to their original position? Has anyone got any experience of the SuperPro consoles/bushes?
Title: Re: Wheels pushed forward due to Anti Lift Kit
Post by: pudding on October 11, 2019, 01:28:55 pm
Offset Console bushes move the wishbone outboard, which has the net effect of pushing the hub forwards (+ caster) because the front of the wishbone is fixed.   This is how all ALK kits work as far as I knew?  The only other ways to achieve positive caster is to rake the top of the strut more towards the bulkhead, or move the lower ball joint forwards.  Anyway, sounds like you need less caster though!
I have the +1 degree caster SuperPro consoles (offset) and they showed no additional caster on the 4 wheel alignment jig afterwards.  They're a bit misleading on that front, or not born out in practice, but either way the stiffer insert improves steering feel and wheel hop though.
Post by: colesey on October 11, 2019, 01:58:29 pm
My Superpro ALK also showed zero change to castor despite the bushes being visibly offset. Bang on 8 deg before and after without the subframe having been touched. I do wonder if VW changed the spec of the factory bushes somewhere along the line?!? Mine is a 2007 chassis.
Post by: RobC on October 11, 2019, 03:21:18 pm
My caster was 8°32 L and 8°24 R before and 8°30 L and 8°27 R after. Wheels are definitely pushed forward. If every console does this Im wondering whether Id be better off with the standard consoles and SuperPro inserts?
Post by: pudding on October 11, 2019, 03:56:29 pm
Standard caster is 7.47 degrees +/- 30 seconds.  8.3 before and after isn't right.  Not sure what's going on there!  I would press in some Darkside Developments S3 bushes to your standard GTI console housings and see if that pulls it back a degree.  You won't want standard bushes as they're voided, and therefore squidgy when you don't want them to be.
Post by: colesey on October 11, 2019, 03:59:15 pm
One of the tricks the racing boys use is to pull the subframe as far forward as possible to maximise castor. Maybe RobC’s subframe was already there to get those readings?!? Anyhow it seems there is a miss-selling issue with Superpro.......
Post by: pudding on October 11, 2019, 04:05:22 pm
Yeah maybe, although I didn't get anywhere near a degree of slack when moving my subframe around.  Mine was stock caster after the Tyrol sport deadset and SuperPro consoles, so yep, when the subframe is mounted dead square + the SPs, you don't get any additional caster.  Maybe SP are relying on people pulling the SF forwards + the bushes to get that degree.
Post by: RobC on October 11, 2019, 04:43:46 pm
OK, you’ll have to forgive me as I dont know enough about these or the effects, my original bushes were worn and so sought these as an obvious upgrade. My issue is I cant afford to keep the wheels where they.
So, on that basis, do you think the subframe should be able to be adjusted by loosening and moving it back enough to put it back where it was? Or will I need to refit the original consoles with uprated bushes?
Post by: pudding on October 11, 2019, 04:49:20 pm
You can try moving the subframe back, but you will need an alignment doing afterwards.  Yep, fit these into your standard GTI consoles if you haven't binned them - https://www.darksidedevelopments.co.uk/products/tt-uprated-wishbone-console-bushes-for-golf-mk5-platform.html
What's confusing is you said the caster was 8.3 degrees before and after fitment of the Powerflex ALK, so in theory your wheels shouldn't be rubbing if nothing changed geometry wise?
Post by: RobC on October 11, 2019, 04:51:34 pm
Thanks Pudding, will look at those.
Apologies, the before reading was taken after the Powerflex bushes were fitted, the alignment was carried out at a different place. Just realised the irrelevance of those numbers!
Post by: pudding on October 11, 2019, 04:56:34 pm
Ah OK, so the Powerflex ALK did actually add a degree, or thereabouts, of extra caster then.  S3 bushes pressed into standard console housings should solve your problem then.  Or you can just buy new GTI consoles but as I say, they're a bit pants.  The S3 ones are solid rubber to get around that splitting problem but don't change the geometry.
Post by: titchy on October 12, 2019, 09:15:29 pm
sorry caster is sugar castor is geometery
Post by: pudding on October 18, 2019, 03:45:28 pm
Lol, there's always one  :grin:  The beauty of the English language is that one can get the contextual gist without requiring the exact spelling, and castor is also an oil  :happy2:
Post by: GVK on October 18, 2019, 03:53:36 pm
*sniffs* mmmm Castrol R  :P
Post by: pudding on October 18, 2019, 03:57:37 pm
And also something to rub on your skin  :grin:
(https://rukminim1.flixcart.com/image/704/704/jk8lz0w0/hair-oil/z/d/z/200-cold-pressed-100-pure-castor-oil-cenizas-original-imaf7mzfy28zqzcc.jpeg?q=70)
Post by: GVK on October 18, 2019, 04:03:00 pm
Wasted on me, I'm bald.  :signLOL:
Post by: pudding on October 18, 2019, 04:08:15 pm
A bald person going by the handle of GVK.....this must mean you are the one and only, Mr Bocking?  :wink:
Post by: GVK on October 18, 2019, 04:13:32 pm
Yes Kev , it is I!  :fighting2:
Post by: pudding on October 19, 2019, 07:19:27 pm
