All Things Mk5 => How to Guides / Troubleshooting => Topic started by: andyp on December 16, 2019, 03:31:36 pm
Title: Replacing pvc
Post by: andyp on December 16, 2019, 03:31:36 pm
Car is hunting at low revs so having had a nosey it seems that it’s poss the pvc on its way out.   Is there any difference bar price between an oem one or one from gsf?   And is a new gasket needed also?   Thanks
Title: Re: Replacing pvc
Post by: GVK on December 16, 2019, 10:40:41 pm
New gasket needed, I have seen them causing lean codes when they leak.
It's the PCV not PVC but whatever floats your boat...
Post by: andyp on December 17, 2019, 11:24:00 am
😂😂.   Didn’t even notice that typo!   So just the gasket instead of the plastic unit?
Post by: bobby_fodge on December 17, 2019, 11:36:35 am
This info was posted on another thread about how to test the PCV
An even simpler test. When the engine is idling pull the dipstick and the engine SHOULD start running rough. When you put dipstick back in and the engine SMOOTHS out again the PCV is ok.
