All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: mayesj86 on January 03, 2020, 01:35:04 pm
Title: Edition 30 manual gearbox
Post by: mayesj86 on January 03, 2020, 01:35:04 pm
Happy new year to you all...….Hope 2020 brings you all happiness and modifications   :drinking:
My gearbox has decided its had enough and called time. Looking at finding a replacement to get overhauled hopefully with a diff then stuck in the car. Been looking and there is so many different gearbox codes. Are all 6 speed manual gearboxes from the MK5 GTI essentially the same?
What clutch kits would you recommend also? Looking for a as stock a peddle feel as possible but with a bit more capabilities?
TIA
Jason
Title: Re: Edition 30 manual gearbox
Post by: muff1991 on January 03, 2020, 01:41:04 pm
happy new year :-)
Probs best to replace your box with the same code, can’t go wrong then. As for clutch kit, I think the TTRS combo goes well and has the OEM feel. I’ve not personally experienced this but read some good things on it. You’ll want to google it or search on here for the exact combo as I can’t remember if it’s stock flyhweel and TTRS clutch or TTRS flywheel. So look into it. Stay clear from performance SACHS or HELIX as you’ll get a stiff pedal and way beyond OEM feel. I’ve experienced those. Good luck
Post by: colesey on January 03, 2020, 03:18:11 pm
Iirc the combo is ttrs pressure plate with a mk5 oem organic friction plate as the ttrs crank runs a different spline fitting to our cars. Is a popular mod stateside and forms the basis of the RSR clutch kit. Would be tempting to go for a sensibly weighted SMF at the same time.
Post by: mayesj86 on January 03, 2020, 03:18:33 pm
Thanks or the reply buddy. Would you happen to know the gearbox code for the eddie. Getting conflicting info just want to be sure. Thanks for the clutch info. Was thinking of that or the RTS clutch kit I think it is. Believe the TTRS route is a standard dual mass and a modified pressure plate from the TT. The SACHS and HELIX from previous experience ( on a different car) were very heavy.
Will look into all that. Thank you very much again for the help. Always appreciated.
Post by: colesey on January 03, 2020, 07:27:36 pm
Not sure of your gearbox code but maybe it’s on the build sticker in the boot? Here’s some light reading for you
www.golfmk6.com/forums/index.php?threads/build-your-own-rsr-clutch-kit-parts-list.273966/
Post by: mayesj86 on January 03, 2020, 08:43:41 pm
That looks awesome that clutch kit. Very close to the RSR kit and they are getting very good reviews. Not sure on the single mass. Last car I changed and it was a nightmare. To be fair it was massively reduced in weight.
Will have a look into the flywheel lots of food for thought now. Really liking the look of that clutch set up.
Thanks again as always great help  :happy2:
Jason
Post by: colesey on January 04, 2020, 08:05:44 am
I always prefer an OEM solution where possible; there’s often too many issues and disappointments with aftermarket stuff. Let us know how you get on as both Pudding and I looked into this a while back but parked it until the work needed doing.
As an aside, it’s worth removing the restrictor from the stock bleeder block for more precise clutch engagement. Free mod!
Post by: pudding on January 04, 2020, 04:28:04 pm
You need to look on your existing gearbox for the specific variant code.  It's stamped into the casing on a flat section at the back, near the dogbone IIRC.
All of the manuals in the MK5 are the O2Q model, but there are variances for R32, diesel and GTI.  Pretty sure the same box is fitted the GTI, Pirelli and ED30 though.  R32 has shorter gearing iirc, if that takes your fancy.  I know it does me.  The stock gearing is way too tall.
The Helix clutch is OK if you get the newer one with their own billet cover plate.  Their older kit which uses the Sachs sporting cover plate is f'kin terrible.  Don't ask how I know.
There's a lot of internet hoo ha about DMFs being a necessity to absorb damaging engine harmonics, but many people are fine with SMFs.   I guess the long term effects aren't known yet, but I f'kin hate DMFs.  They are an utter abomination.
My clutch (helix) and DMF are fooked and due for replacement.  Think I'll be going down the TTRS cover plate and OEM MK5 disc route personally, with a new OEM DMF.  Pattern ones are garbage and last 2-3 years tops.  Again, don't ask how I know  :grin:
Post by: muff1991 on January 05, 2020, 10:00:01 pm
Thanks all for confirming the combo I was trying to bang on about, I couldn’t remember exactly. Lol
Post by: GVK on January 06, 2020, 08:38:53 pm
R32 gearbox will have a different casing for the 6 cyl engine surely?
+ transfer box and 4wd gubbins...
Post by: LC5F on January 07, 2020, 06:02:49 pm
Get in touch with Mart from Gas N Gears on Facebook - https://www.facebook.com/gasngears/ (https://www.facebook.com/gasngears/)
He can rebuild your box supply and install Quaif's cheaper than Awesome or Darkside - very talented guy
Post by: GVK on January 07, 2020, 08:55:09 pm
Another shout for Mart at Gas n Gears , very helpful when it comes to VAG transmissions.
Post by: mayesj86 on January 08, 2020, 12:37:55 pm
Thanks for the great info as usual Pudding. I'm currently weighing up my options with the car. Apart from gearbox and the need for an exhaust ( The quality of the milek SS exhaust are shocking considering the price) mechanically she is sound, body work however is in need of some TLC and paint.
The gearbox is laying on the garage floor as I type as well as the exhaust. Not sure if it is worth rebuilding the gearbox, new exhaust and paint to get her where I want it or break her for parts ( No MOT failed on a holed exhaust). Be the best part of £2K to mechanically sort her and another couple of grand to paint. Absolutely loved the car but have fallen massively out of love with her just now. Not sure if I wait and see if the love returns and bring her up to scratch, fix the mech issues and sell on ( probably loosing monies in the process) or break out for parts  :thinking:
Will do so reserch into pricing of the clutch kit I do like the sound of that clutch. Looks like you can get a pre made kit with a SMF or DMF. I have no noise off the DM or clutch slip but if ive gone to the trouble of removing the box would be insanity not to replace clutch, flywheel and release bearing when I'm there.
I have the luxury of a garage and time so could just fix in dribs and drabs ( Now own a caddy Maxi for everyday running and transporting the motorbikes to tracks). Cant decided what to do just now.
Thank you very much for the info will give him a shout and see what the damage will be. Only issue is I live in central Scotland and have massively lost the love for her currently.
Post by: LC5F on January 08, 2020, 09:58:35 pm
If the love returns, distance isn’t an excuse - I’m in Edinburgh, I sent my Lupo box down on a pallet to Mart for rebuild and Quaif - and he lightened the flywheel by a third
Post by: pudding on January 10, 2020, 05:19:18 pm
Yep, but I was thinking more of swapping the gearset/final drives over than using the whole box.  I think the R32 box will bolt onto the FWD bell housing though.
Post by: pudding on January 10, 2020, 05:28:27 pm
Yeah that is a dilemma that faces us all unfortunately. Persist with the old girl, or throw the towel in for something newer.  The MK5 is now at that age where major components like steering racks, gearboxes, engines, turbos etc aren't far off writing the car off if the bodywork isn't minty fresh  :sad1:
I keep toying with the idea of converting to DSG but it's a faff and expensive.  I don't have the luxury of a garage so it would have be dropped off somewhere for a few days, bumping up the final cost even more!
How bad is the bodywork?  That can also write the car off if it needs a complete respray.  I know mine does with the sheer amount of stone chips  :grin:   Good wraps are now the same price as an average blow over, so which ever direction you take, it's big £££s.
I'd persevere with it personally.  Bodywork can be done DIY to an OK standard if you're patient, just so long as it keeps the rust at bay, which is the main thing.  MK6s and MK7s do nothing for me what so ever, so I'm trying to keep mine going for as long as possible also.
Agreed on Milltek.  I really don't get the fascination with that brand.  A lot of money for the averageness of the quality.  I'd rather fork out for a new OEM system (if available) than go aftermarket tbh, but there are some good options in the USA though  :happy2:
