All Things Mk5 => Mk5 General Area => Topic started by: goku4ever on January 10, 2020, 11:06:42 pm
I've purchased a rns510 headunit which was removed from a T5 van. I haven't received the unit yet.
The part number is 7f0 035 680 D SW: 6276.
My question is what is the difference between the above unit and 1t0 035 680 D?
Will I have any issues installing into my MK5 (I've changed my canbus to L revision)?
And finally where can I get the code for it, will those sold on eBay work?
Thank you
(https://uploads.tapatalk-cdn.com/20200110/9c5f912707e5ec1ea8c4fca2849649f6.jpg)
The main difference between them is the speed and screen quality. They will all fit into a MK5.
Much later ones got an SSD hard disk and LED screens. I used to have a Revision A and I could drive to the end of my road (about half a mile) before it started playing music after turning it on. Very slooooooooooow :grin:
Later ones also tend to have the battery drain issue solved with better firmware, or something, so no need for a newer CAN gateway. I've left mine at Gatwick for 2 weeks and the car started no probs when I got back. That was a revision Q with the original MK5 can gateway.
r32
