All Things Mk5 => Mk5 General Area => Topic started by: Dunkdafunk on January 19, 2020, 04:47:49 pm
Title: New cam shaft
Post by: Dunkdafunk on January 19, 2020, 04:47:49 pm
Replaced the intake camshaft with a new one. Its aftermarket and not an oem. The engine sounds like the tappets are gone, and its temperamental . Does the hydraulic lifters need time to bed in? Do they shift about with a new camshaft?
The intake specified degree is 28, but actual varies from 38-45 and its had a new timing chain. The idle is kinda rough. Could the hydraulic lifters noise come from an intake air leak?
Air leak code on vag com. No other codes.
Title: Re: New cam shaft
Post by: ROH ECHT on January 19, 2020, 08:36:55 pm
Can you add; why you replaced the intake cam and the exact error code nomenclature, not the description of the code? The description you gave have me leaning toward a vacuum or PCV system leak. But You may receive more help by adding the above which I requested.
Post by: Dunkdafunk on January 19, 2020, 08:56:19 pm
Replaced due to pump lobe wear. Code was deleted, so description that come up was air leak in intake system. I can confirm there is a leak, the turbo boost is weak so il try and find the leak, report a code and go from there.
Just didnt think a leak could cause 45kw angle and a tapping noise that sounds like the hydraulic lifters. Seems to be the hydraulic lifters thats making the noise. If the hydraulic lifters fail when you change a camshaft, does that mean the camshaft lobes are not design spec? or could the cam cradle be bolted down not hard enough and cause a gap between the lifters? can the lifters pop out of there cradle?
Post by: FJB on January 20, 2020, 12:02:50 pm
Are you sure you are not one tooth out on the cam chain? The lifters work with oil pressure, they fill with oil and expand, unlikely that changing the camshaft would cause them to fail, perhaps they were already noisy and you didn't notice. When you refitted the cam ladder you should have replaced the bolts and torqued angle to spec, they are one use only.
Post by: Kee1994 on January 20, 2020, 03:10:21 pm
On my old s3 8p I had the cam chain tensioner changed wasnt timed up right , had rough idle revs kept bouncing on tickover.
Sent from my SM-G973F using Tapatalk
Post by: ROH ECHT on January 21, 2020, 02:06:05 am
I also would be inclined to believe the cams are not timed correctly. You may need to have another look at the cam timing. Do you need help with that or are you having a shop do the work?
Post by: Dunkdafunk on January 22, 2020, 06:43:04 pm
I'm happy with the cam ladder. There was a loose pcv connection and this was the leak.
How would I adjust the timing? I thought the vvt did that? I used the cam lock tool to line up the exhaust and inlet, and just swapped over old for new. Should I have done something else?
Kee 1994, you had tensioner issues? And ur timing was out? I'm assuming you adjusted the timing?
 I am getting g247 fuel pressure sensor malfunction. It idles bad like the timing is out, but I was specific in like for like when swapping over. It's been working great before the new intake, and it had a new timing chain and tensioner. The exhaust cam is original. How would I use the vag com to see if I am one tooth out, angle kw? Static kw? Or what tools could I use? I cant take it to a shop I'd like to do it myself. I've cleaned the cam sensor and earth contact which runs in the same loom as vvt and fuel valve reg.
Post by: ROH ECHT on January 22, 2020, 07:54:48 pm
One doesn't physically adjust timing. The VVT system does this. What usually happens is someone can misalign the cams when they are working on replacing the timing chain for the cams.
Post by: Dunkdafunk on January 22, 2020, 08:14:10 pm
Well I'm yet to inspect the hpfp and I am getting fuel codes. Could the hpfp piston have broken? I definitely lined up the cams with the lock tool, and there was a notch on the intake sproket that helped mark the chain. One whole tooth out would have been hard to achieve with the lock tool.
Post by: FJB on January 23, 2020, 04:06:50 am
When you have locked the cams you need to put the chain on with the lower side of the chain being taught or the timing will be out. I have seen people make the mistake of the chain being taught on the upper side. It will be easy for you to check if you have the locking tool, remove the valve cover, rotate the engine by hand, and see if the tool will fit, if it fits properly the timing is good.
Post by: Dunkdafunk on January 23, 2020, 06:52:20 am
FJB I dont think I checked the tension. In fact it could have been slack at the bottom. Can you just lift off the side cover and top cover, lock the cams and release the chain tension?
Post by: FJB on January 23, 2020, 07:56:24 am
If it was slack at the bottom it will likely be out of time. Lock the cams, remove the adjuster housing, push the chain tensioner down and use a small nail or allen key in the hole to hold it down, and see if there is enough slack to move the chain to the correct position. If not you will have to remove the the cam adjuster form the end of the exhaust cam.
Post by: Dunkdafunk on January 23, 2020, 08:07:04 am
Will do. I think this has been the problem. I used the marking from the chain, how isit that the tension differs? I work with Motorcross bikes so I've always been used to a tense and slack side. Isit because of the vvt pulley or did I miss a link? If it's been out of cam timing, do I need to check anything that could have broken? Valves etc?
Post by: FJB on January 23, 2020, 08:37:50 am
If when you changed the camshaft you marked the chain at both cam sprockets, then transferred the inlet cam mark to you new cam, then lined it up when you put it back together then it wont be out of time. It will only be out of time if you locked the cams with the tool and fitted the chain with the bottom slack. If it has been out of time and only by one tooth you may get away without any damaged. The only way to know for sure is pulling the head.
Post by: Dunkdafunk on January 26, 2020, 12:06:34 pm
I'm abit lost.
Stripped down cam ladder and re-done the chain number of links. It's done by 18th and 19th link rather than the tool, which also fits in. It's an after market inlet cam shaft J revision correct part number. My engine is a bwa 2006 but for some reason come with an A revision intake?
It's got 182k miles on.
Worked fine before inlet cam replacement, apart from worn fuel pump lobe because it's a revision.
It runs poor on idle, and jumps between 35-48kw inlet angle, angle doesn't steady on idle. It's got what I think is a valve noise, which sounds like the normal tappet and goes away at 2-3k revs. I'm getting 115psi compression identical across all cylinders. The tappets noise did go away for 10minutes or so driving, then come back and has stayed.
It's got an after market exhaust cam pulley. After market chain and tensioner. Original oem exhaust cam that's got 180k miles on. This set up worked just fine. Now it's got an after market intake cam. could the tolerances be accumulated? Could the vvt solenoid be broken (reads 7ohms) or inactive? Could the hydraulic tappets with a new cam shaft be dry?
Post by: pudding on January 26, 2020, 01:45:37 pm
48kw is beyond the maximum advance of the VVT adjuster, so the timing is miles off by the sounds of it.   Probably explains why your compression readings are about 90psi off spec if the inlet valves are opening way too early.
I would get a used genuine cam and genuine parts for the other bits and go back to the drawing board personally.
Post by: Dunkdafunk on January 27, 2020, 11:47:21 am
The after market parts dilemma has been hit and miss for me. Ive bought parts that have done so well and cost me alot less. And then theres parts, which i would have thought if your going to the effort of 3d tracing and reverse engineering a camshaft, then surely they would have tested it with approval. My thoughts are the cam journals with 180k dont work well with a new cam. I dunno.
None the less iv grabbed a good second hand J revision. Cheers Pudding. Will give that a go.
With regards to hydraulic lifters, can i take them out once the cam is off and make sure they are filling ok? do i need any special tools or isit just best to lift the rocker off and fill with oil?
Also does anyone have any decent pdf's or links for the vw or other valve train designs and oil flows etc?
Post by: FJB on January 27, 2020, 04:16:05 pm
Once the cam is out just lift the rollers with the lifters attached and separate them. To reinstall put the lifters in the hole then put the rollers in place and push down hard until they click in. You will see what I mean as soon as you have them in your hand. You can either clean them with an ultrasonic cleaner or parts washer, or replace them.
Post by: Dunkdafunk on January 27, 2020, 06:27:28 pm
Cheers fjb
Post by: Dunkdafunk on January 29, 2020, 08:34:18 pm
Found out one of the main issues with my new aftermarket 100 quid intake cam.
It's been reverse engineered, and with this in mind they have put a massive fuel pump lobe on. Maybe thinking it's a consumable part, or there material isnt as good as what it should be so accommodated for wear? Iv not checked with a vernier but I'm guessing the valve lobes will be slightly bigger aswell.
Recieved the second hand low mileage original vw J revision, and it's pump lobe is no where near the size of the aftermarket one. The top of the triangle lobe shape reaches nearly just about the top of the chain when it's on the sproket. And on the original it sits kinda below the chain. So I'd say an extra 3-5mm extra on the pump lobe alone. I duno how to put pics on here but it looks mad. Im thinking the knocking noise has been the actual fuel pump reaching its piston stroke end, as I had fuel codes coming up. I should have used a vernier before putting it in. Worth noting.
Post by: muff1991 on January 29, 2020, 10:29:03 pm
After market parts unfortunately, can I just point out too... even with the cam locking tools you can get the inlet cam a tooth out, they can roll back from the valve compression, I know because it happened to me the first time round! Had to double check everything. Eventually noticed one of the cam lobes wasn’t pointing in the correct direction. Looking face on at the lobes from the timing chain side, the 2 lobes should be points towards each other (left cam lobe facing 10 past and right cam lobe facing 10 too) hopefully that makes sense.
Post by: Dunkdafunk on February 02, 2020, 01:47:14 pm
Fitted new camshaft that's vw. Fitted via 18th 19th pin. Chain is new ish. After market pulley is on which come with the timing kit a while back.
Previous aftermarket intake cam lobe profiles were not as bad as i originally thought in my previous posts. Massive weight difference tho between vw material and aftermarket steel.
The chain tensioner had its filter on the back semi blocked/blocked, so the chain tensioner piston was quite hard to move down. Cleaned it up and moves freely. The vvt solenoid operates when connected to a battery and has 7ohms.
Could the vvt pulley be blocked, or the housing oil passage? Can you take the vvt pulley apart?
I think the sealing rings, maybe plastic, have broken? Does anyone know the part number for the vvt plastic rings that go inside the timing case?
What's the knocking sound, the vvt pulley with low oil pressure?
I'm getting these codes, along with a loud audible clicking/tapping sound which seems to come from the vvt pulley side.
00010 camshaft positioner bank 1 intake slow response short circuit to another valve
004506 fuel pressure sensor (g247) malfunction
000021 bank 1 CMP sensor (g40) / engine speed sensor (g28) incorrect correlation
Post by: FJB on February 02, 2020, 05:54:54 pm
The rings come in a pack of 3, part # 06F198107A
Post by: Dunkdafunk on February 02, 2020, 07:33:43 pm
Cheers FJB. Much appreciated.
Does anyone know why these rings are so expensive? What material they are? Shame you cant just 3d print them
