All Things Mk5 => Mk5 General Area => Topic started by: chimp400 on March 09, 2020, 08:35:04 pm
I’d like to fit a set of rear sensors and wondered does anyone know if the rear bumper on a 2008 Edition 30 would be pre marked on the inside for drilling?
I was looking at fitting some of these.
https://www.ebay.co.uk/itm/Colour-Coded-Rear-R0394-Cobra-Parkmaster-OE-Style-Flush-Mounted-Parking-Sensors/272124290473?epid=1623633620&hash=item3f5bdf25a9:g:OdYAAOxySoJTQqq5
I don't think they are, but it's easy to put them in the right spot just by looking at pics of other cars on Google Images, they don't have to be mm precise.
I purchased one of these https://www.ebay.co.uk/itm/391831521782 and it makes a very clean cut exactly where you want it (after making a suitable smaller pilot hole of course). 18.2mm is the common hole size that all genuine VAG/Skoda cars use, not sure about the cobra system or how OEM they are.
This is the system I purchased https://www.aliexpress.com/item/32866042537.html? Completely OEM (I have an RNS 510) but does require some coding and effort to fit nicely.
If you've got an ED30 it's worth doing right, no? :happy2:
Good luck
Stu
Thanks, that looks a very comprehensive kit. I believe I have the RNS510 head unit so although it looks a lot of work it would probably be more keeping with oem.
