All Things Mk5 => Mk5 General Area => Topic started by: fahim4094 on April 03, 2020, 05:19:06 pm
Title: MK5 GTI EDITION 30 RADIATOR FAN
Post by: fahim4094 on April 03, 2020, 05:19:06 pm
Hi guys,
I've got an mk5 GTI Edition 30 BYD - my radiator fan is constantly running both of them - (Small fan/BigFan)
Error code: P2184 - Engine Coolant Temperature Sensor 2 (G83), Circuit Low.
My mechanic replaced the coolant temp sensor but that has not resolved the issue.
I have been advised it could be my radiator fan motor and I may need to replace my radiator fan - I was wondering would a AAX radiator fan work on my edition 30.
Title: Re: MK5 GTI EDITION 30 RADIATOR FAN
Post by: GVK on April 03, 2020, 08:22:38 pm
Did you know there are 2 coolant sensors?
one below the edge of the head (easy to access)
another behind the alternator (not so easy to access)
I don't know which G83 is though.
Post by: Dave_M on April 03, 2020, 09:47:06 pm
I had the same on my Edition 30.  Swapped both coolant temperature sensors but still had same problem.  It turned out to be a break in the wiring at the connector clipped to the front of the gearbox.  Only found it by plugging in VCDS and wiggling the wiring.
Dave
Post by: Cosmos on April 04, 2020, 08:57:25 am
I had a problem recently with both fans nearly constantly on,on my wifes mk5 1.9tdi and it turned out to be a faulty air con switch. Replaced it and re gassed the aircon and the fans arent on now.
