All Things Mk5 => Mk5 General Area => Topic started by: SamwiseG on May 04, 2020, 01:13:36 pm
Title: Gateway / canbus
Post by: SamwiseG on May 04, 2020, 01:13:36 pm
I have recently installed an rcd330 into my 2006 golf and I now having a battery drain issue. Does anyone here have a pre coded canbus I could buy or know where I can get one pre coded to stop this issues ?
Cheers sam
Title: Re: Gateway / canbus
Post by: PirelliAu on May 04, 2020, 03:43:05 pm
I have the same issue and have had it ever since I bought the car with the rcd330 installed. How do you get rid of it? I miss being able to listen to music in my car without having to turn on the engine for a good hour in my old 2007 outlander haha
Post by: SamwiseG on May 04, 2020, 08:11:36 pm
I’m not sure, if i find a solution I will let you know. Hopefully someone can point us in the right direction  :smiley:
Post by: bacillus on May 05, 2020, 12:59:58 pm
you should be able to get a correctly coded canbus provided you can tell the seller what the original configuration of the car hardware is. This unfortunately may mean a vcds scan to see what modules your car has installed so that info can be coded to the new canbus.
whereabouts are you as there is a list of members with vcds who may be able to do a scan in the vcds forum here.
Post by: LC5F on May 05, 2020, 04:10:54 pm
The short term quick fix is changing the power to ignition os outlined here:
https://www.mk5golfgti.co.uk/forum/index.php?topic=37977.0 (https://www.mk5golfgti.co.uk/forum/index.php?topic=37977.0)
Post by: SamwiseG on May 06, 2020, 10:18:08 am
Thanks for your replies everyone, I am in Norwich @bacillus (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=49) , I don’t have the equipment to do this myself, if you know of anyone that would be great. I have spoken to a couple vw specialist garages and they’ve quoted me around £100 to get the canbus updated but have said it will be more if I need a newer canbus.
Post by: bacillus on May 06, 2020, 11:52:12 am
look to see if anyone in your area  on this thread can help, https://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
If you plan to fit yourself (it's a pain for most) then see if anyone with vcds on the list can help take a scan to see what modules are installed. Get a printout or made a note of what's installed.
You can then install an uncoded newer canbus (it can be an used coded one as well) then get it coded using vcds. that part is easy to do if you've had an original vcds scan.
hth
Post by: SamwiseG on May 06, 2020, 12:41:22 pm
Thanks @bacillus (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=49). I am still very unsure with what do do. I don’t really under grand scanning as I don’t have the equipment so I’ll check in the thread. Thank you so much for you help it’s much appreciated
Post by: LC5F on May 06, 2020, 04:19:50 pm
You will need a new canbus, the issue is your current canbus does not know how to power down your new head unit.
The job is only half an hour so £100 sounds a bit steep
Post by: SamwiseG on May 06, 2020, 10:29:43 pm
@LC5F (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=49808) oh I see now that makes sense. would a canbus out of a mk6 do the job ? And then just find a garage to copy my cars config over to the new one do the job ?
Post by: Dannyboi#722 on May 06, 2020, 11:58:17 pm
Sam drop me a message with your number as can’t dm you 👍
Post by: SamwiseG on May 07, 2020, 11:25:58 am
@Dannyboi#722 (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=21186) have you got any socials I can get you on to send my number mate ?
Post by: Dannyboi#722 on May 07, 2020, 11:53:56 am
Here’s my number 07548507841 give us a call. @SamwiseG (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=70946)
Post by: LC5F on May 07, 2020, 05:15:57 pm
Yes - lots of stuff online - but Dannyboy should sort you out
Post by: burtz on May 09, 2020, 10:03:15 am
I was under the impression if you buy a Rev L or newer canbus, you can just plug it straight it and it would work? Or do they always need coding? I'm a bit confused lol
Post by: terrier on May 09, 2020, 10:10:59 am
Will need coding.  This can be done remotely Pretty sure someone on here will be able to do it :happy2:
