All Things Mk5 => Mk5 General Area => Topic started by: mouldb on September 02, 2020, 04:26:39 pm
My GTI is drinking oil & I have some persistent fault codes which re appear after clearing.
I would be grateful for any advice you may be able to give based on your experience of similar faults
Thanks in advance.
I have scanned & uploaded..
Wednesday,02,September,2020,15:53:31:01249
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ1KZ7W059905 License Plate: V10ULD
Mileage: 148100km-92025mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7W059905 Mileage: 148100km-92025miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0F8097584
Coding: 0403000318070160
Shop #: WSC 00791 210 87297
VCID: 2D56C5FFB415DF56C6-8078
5 Faults Found:
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148093 km
Time Indication: 0
Date: 2000.00.00
Time: 15:26:31
Freeze Frame:
RPM: 1400 /min
Load: 12.9 %
Speed: 38.0 km/h
Temperature: 88.0°C
Temperature: 44.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148093 km
Time Indication: 0
Date: 2000.00.00
Time: 15:26:41
Freeze Frame:
RPM: 751 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 46.0°C
Voltage: 13.589 V
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148098 km
Time Indication: 0
Date: 2000.00.00
Time: 15:35:31
Freeze Frame:
RPM: 803 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 48.0°C
Voltage: 13.970 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected.
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148102 km
Time Indication: 0
Date: 2000.00.00
Time: 15:41:08
Freeze Frame:
RPM: 1048 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 44.0°C
Voltage: 14.097 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148102 km
Time Indication: 0
Date: 2000.00.00
Time: 15:42:46
Freeze Frame:
RPM: 2971 /min
Load: 14.5 %
Speed: 41.0 km/h
Temperature: 92.0°C
Temperature: 31.0°C
Voltage: 13.970 V
Readiness: 0110 0101
Well, you have a code for an intake leak or runner flap fault. Another for fuel pressure out of spec. And one for the DV/N249 failure.
If the DV is OK, then the DV code may be related to the code for a leak in the intake system.
Most common reason for the P1093 code iis the pressure regulator on top of the HPFP is cracked. If that is OK, then it may be the Cam follower is failed or the fuel is not being delivered by the LPFP...the fuel filter can also restrict flow. It is also possible a fuel pressure sensor is failing. The P0507 can be the throttle unit, but if not...it may be a vacuum leak. Given you have the intake system leak detected...I would say begin looking for a major leak in the air inlet bits and all tubing connected to the manifold. If you find this leak, you may find it is responsible for all of the codes other then the DV.
Thank you for your response that is most helpful I shall check it out out and post my findings
