All Things Mk5 => Mk5 General Area => Topic started by: Eddy30_vinny on October 27, 2020, 01:25:50 am
Hello I’m new to this site hoping someone can help me out with some info as to what mite be wrong with my eddy30 I have no compression on cylinder one two and three are 70psi and four is 150psi now am I right in thinking that maybe the head has lifted or what as I’m lost 😞
could be worn piston rings have you checked the spark plugs are seated correctly? Have you done a wet test?
Broken pistons at a guess , ringland failure.
Head off, sump off, pistons out. :sick:
Heads don't lift on these engines unless running silly boost from a hybrid turbo, or massive detonation.
As you haven't mentioned the spec of the engine at all, I'm going to hazard a guess it's had a Stage 2+ remap, with pops and bangs (natch), and it's either burnt out the exhaust valves, or smashed the ring lands as GVK said.
If the latter, you got off lightly, throw a new head on it and go about your business.
If the former, chuck the motor in the bin and get a new one.
It is a stage3 no pop and bang and it has a bbt 430 k04
