All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: candy turbo on March 20, 2010, 04:20:21 pm
has anyone fitted the tv tuner module to there sat nav (rns e or rns 510 ) is it easy to connect up , where does the unit fit ? :happy2:
:smiley:
Trust me when i say this......I don't work for this company and I do not make profit from pluging it.
Hazzydays limited retrofit original vw/audi products. Their site also lists the tv tuner mod you have mentioned. They use Ampire DVBt 200 for the RNS510 and the RNS-E, I believe.
The site address is www.vwcruise.com
Speak to Gareth Hawkridge. Knows his stuff. I had the bluetooth/ voice activation, MDI fitted to my edition 30. They did an excellent job.
Hope this helps? :happy2:
Brendan.
cheers but thats expensive , there s a unit on ebay wondered how hard it is to fit ?
i was looking at putttingtv audio in my car but i got told the aeriel will be on the outside which i didn't want
Kufatec do the ampire kit ive translated it, you would need to speak to Kufatec or Richter Sport in the UK cos im not if its for the RNS510/RNS-E you would need to find out. 299Euros
http://www.kufatec.de/shop/product_info.php/info/p944_DVB-T-Diversity-Receiver-Ampire-DVBT200-Testsieger.html (http://www.kufatec.de/shop/product_info.php/info/p944_DVB-T-Diversity-Receiver-Ampire-DVBT200-Testsieger.html)
Dualer DVB-T Receiver Ampire DVBT200
Optimal für den mobilen TV-Empfang geeignet
Dieser Tuner verfügt über zwei eigenständig arbeitende Empfangseinheiten, welche eine überragende Bild- und Tonqualität gewährleisten, auch bei hohen Geschwindigkeiten
Flimmerfreie, digatale Bild- und Tonqualität
Merkmale DVB-T Receiver
Zwei eigenständig arbeitenden Empfangseinheiten (Dual - Tuner), welche eine überragende Bild- und Tonqualität gewährleisten, auch bei hohen Geschwindigkeiten
2 Antenneneingänge aktiv/passiv Type F / Buchse
3 Video Ausgänge FBAS (Cinch)
1 Stereo Audio Ausgang (Cinch)
2 AV Eingang (Cinch)
Einschaltbare 5V Phantomspeisung für aktive Antennen, die eine Phantomspannungsversorgung benötigen
Digitale Rauschunterdrückung für den Audioausgang
EPG/ Tele Text
Quick-Scan
Videospiele integriert und per Fernbedienung spielbar
Abmessungen 131mm x 175mm x 25mm (LxBxH)
Lieferumfang
DVB-T Receiver
Fernbedienung
1,5 Volt Batterien für Fernbedienung
Anschlusskabel
Bedienungsanleitung Deutsch/Englisch
Hinweis
in Verbindung mit IMA Multimedia Adapter Basic Plus benötigen Sie weiterhin Artikelnummer 35549
I had a play with a Alpine DVB-T tuner and the above IMA, when it worked, it was ok when standing still, but when the ima didn't want to play, it was a right pig to change channels and rescan when in a different area.
Ripped it all out whdn I fitted my rear view camera ( both the ima and rvc needed to use the same socket) and didn't miss it
Cheers Barry, Candy not sure what the OEM one is like but from a Volvo V70R I had the tv is not the best.
Darren
