All Things Mk5 => Mk5 General Area => Topic started by: Raziel on April 12, 2021, 07:32:46 pm
Hi guys, went for a spirited drive at the weekend, car drove well but when I got home it sounded rough, when I turned the car off and restarted it sounded better. I have, a few months ago replaced the PCV, cam follower and cam chain and tensioner. I smoke tested the intake and there is a leak at the back of the engine around the rear PCV area, would that cause this or is it something else? Any help will be greatly appreciated.
Hi Raziel could you describe "rough" in a little more detail please?
Max
Lumpy and uneven idle, an a bit of a rattling sound.
Can you post a video of the noise and are you able to check for fault codes?
I do have a video but I don’t know how to post it.
Upload to YouTube and post the link. I think that's your best bet.
Any air leak will make it idle bad as the system is working in a vacuum state.
Need a decent scan tool really, to A) make sure no sensors are flagged as defective, and B) check the long term fuel trims.
