All Things Mk5 => Mk5 General Area => Topic started by: pandaman on June 19, 2021, 12:42:37 am
Title: coilover suggestions
Post by: pandaman on June 19, 2021, 12:42:37 am
I've had H&R 30mm springs and stock shocks for a few years now and they are starting to show it.
(https://i.imgur.com/EOnmnRr.jpg)
I'm thinking coilovers to replace them, but i have no idea at all where to start.
Can they be a softer/comfier ride than just springs? good brands? brands to avoid?
Any help appreciated.
Title: Re: coilover suggestions
Post by: GVK on June 19, 2021, 01:00:10 am
I wouldn't bother with coil overs for a road car unless you're into KW/Bilstein quality  (£1000) -I'd rather spend the money on a set of B8 Bilstein shocks which are OEM style but shorter to match your springs, I'm going down that option with mine at some point.
Check out Demon Tweeks for pricing.
In my experience all coil overs do in this country is go rusty and then they seize up so you can't adjust them anyway! The cheaper ones are fixed damping , usually way too stiff for a bumpy road , so pretty useless.
Of course you can get things like AP coil overs for £300? (Just checked they're £540) that most people are happy with. All depends on the use and your needs.
All my opinion of course.
Post by: pudding on June 19, 2021, 01:40:52 am
The cheapest and best upgrade would be to add Bilstein B8 dampers to the H&R springs.  I would get MK6 ones as they're more forgiving.
Coilovers are a blue pill vs red pill thing.  A rabbit hole you don't want to go down unless you have specific requirements!
I can honestly say coilovers are the most over rated bags of sh1t I've ever experienced on a road car.  Even expensive ones.  The best ones I've used are Ohlins but you'll be coughing up £2.5K for them, they'll last 30,000KM (yes, KM, not miles) and you will get ZERO support if they fail, which they WILL.  But for the short window they last, they are utterly sublime. As for cheap £300 JOMs and the like, I wouldn't fit those to a scooter let alone a car.
EDIT: GVK beat me to it.  Most coilovers are, at minimum, twice factory spring rate (they have to be due to the lowered roll center) so ride comfort will be terrible.....except....where the dampers are rebound/compression adjustable and top quality tuned to the spring rate and vehicle axle weights.  Cheap ones aren't.  A lot of suspension makers just chop the springs down an arbitary amount without actual on-car testing.  That's why I went with Ohlins because they do 6 months road testing before releasing to the public, but even that level of diligence doesn't gaurantee a reasonable life span  :doh:  See, I did say red pill...... just take the blue pill (B8s) for an easy life.
Post by: GVK on June 19, 2021, 01:54:38 am
Haha, can't you tell we're old?  :innocent: :grin:
https://www.onlinecarparts.co.uk/bilstein-633680.html rear mk5 fitment 24-178006
https://www.onlinecarparts.co.uk/bilstein-1044333.html (late mk5 55mm fronts) 35-108191
Early mk5s have different diameter front shocks where it goes into the hub but I'm not sure on the change-over year?
It took me ages to find the mk5 part numbers let alone the mk6!
Post by: pudding on June 19, 2021, 02:05:40 am
With age comes wisdom  :grin:  We've taken the hits so others don't have to  :happy2:  Blimey, you and I have been in the VW modding thing since the 90s  :surprised:
50mm struts is pretty much just 2004-2005.  55mm from 2006 on.
Tell me about it!  Bilstein's catalogue couldn't be any more convoluted if they tried!
B8s for the MK6 TSI/TDI are the fellas to get....although it's worth confirming they can cope with uprated ARBs and/or specific lowering springs as they can be a bit funny about that and pull the warranty.
Post by: GVK on June 19, 2021, 02:08:55 am
I'll do some research on the mk6 stuff.
Yeah you're right between us we have been pi55ing around with these things since the 90s  :rolleye:
Good to have a bit of banter too.
Post by: pudding on June 19, 2021, 02:22:17 am
I can't remember the specifics, but it's widely acknowledged Bilstein softened the valving on the MK6 dampers over MK5.  'The Bruce' is the VAG suspension whizz but he hasn't been around for years on here.
How things have moved on from our basic MK2s and Corrados  :grin:  I do miss my Turbo Technics MK2 16V though, that thing was Inner City having Big fun!
The best kit for folk wanting a mild, circa -10 to 15mm drop with decent ride, is the B12 Pro kit for 1.4/1.6/TDi MK6.  Otherwise it's the MK5 B12 Sportline kit which is lower and stiffer.
Either way, everyone needs monotubes in their life.  Ask any girl if she wants a throbbing great monotube, or a weedy little twin tube, it's mono every time.
Gotta have the bants  :happy2:
Post by: GVK on June 19, 2021, 02:30:43 am
Yeah things move on from the days of mk2s etc. I remember getting a 16v head off Dave Crissel for £300 which gained me about 10-15bhp If I remember, nowadays thats what I spent on a remap to gain  ~ 80bhp or whatever lol! Do miss the  last mk2 though, was great with the VR6.
(https://live.staticflickr.com/65535/51257136440_6f23275074_n.jpg) (https://flic.kr/p/2m6qdTJ)GVK (https://flic.kr/p/2m6qdTJ) by GVKmotorsport (https://www.flickr.com/photos/gvkmotorsport/), on Flickr
(Sorry Pandaman, we digress)
Post by: chimp400 on June 19, 2021, 11:27:28 am
Springs will be fine, a few years use won’t hurt. Probably time to just upgrade the dampers, top mounts etc.
Post by: GVK on June 19, 2021, 11:57:04 am
That's my plan hence asking about the TTRS mounts etc.
Same should apply to the OP
Post by: imprezzaworks on June 19, 2021, 08:07:20 pm
How much are the b8 shocks
Post by: GVK on June 19, 2021, 08:09:58 pm
£144 each front £113 each rear on the links I have posted.
Post by: imprezzaworks on June 19, 2021, 08:11:09 pm
Cheers. Misses the links ha ha.
Post by: imprezzaworks on June 19, 2021, 08:12:23 pm
Wonder if the likes of ecp can get them.
Post by: GVK on June 19, 2021, 08:13:07 pm
Maybe, I have seen them on there while ago.
I think the links I put above are from a spin off company of GSF car parts.
Post by: pandaman on June 20, 2021, 11:23:05 pm
I think ill take the blue pill....
So, Bilstein B8 shocks, MKVI ones so they are more forgiving.
Cheers everyone
Post by: GVK on June 20, 2021, 11:41:08 pm
Let us know how you get on with them.  :happy2:
Post by: pudding on June 26, 2021, 01:49:16 am
I don't get the rub with the TTRS top mounts.  Well, to be more accurate, they are just TT mounts.  TT and TTRS use the same mounts.  There is no 'RS' factor to get excited about here.
They make the same rubbery squelching noises over speed humps as the GTI ones do (with some aftermarket suspension kits, but not all), so I'm not entirely convinced they are an 'upgrade' tbh. Basically, uprated aftermarket dampers are a lot stiffer than OEM, hence the rubbery noises. It's not a major concern as long as you are aware of it, though.  Doesn't do it all the time, just on slower moving, larger humps/lumps.
034 Motorsport dissected OEM mounts (inc TT 'RS' ones) and found the problem (big thread on VW Vortex about it).  Their street or track density mounts are probably a better mount tbh, but I don't think they come with bearings, so are roughly the same price as OEM TT all in, given the import duty nonsense.
The absolute best top mounts are made by Ground Control....but erm, who fancies paying £465 for them??
Post by: pudding on June 26, 2021, 01:58:33 am
Cheers everyone
I would.  They will prop up your existing springs nicely (nothing wrong with H&Rs at all, they are good springs) and it spares you the expense and inevitable disappointment of coilovers.
I'm not against coilovers, its just that to get a decent ride quality and life span, you have to spend a LOT more money than the average kits.  Having been there and got the T Shirt, I won't sit by and watch people waste their money and end up not enjoying their car.  There are some really good coilovers out there, but there is also a lot of trash that gives them a bad name.
Post by: PKGTI on August 24, 2021, 08:44:39 pm
I have just bought a MK7 GTI for family duties so have taken on the MK5 for my daily 80 mile commute. I have very nearly gone for the B8 option a few times but have hesitated as I worry it will ultimately spoil the handling. Even with 118k miles, when you really get on it, the MK5 handles brilliantly.
I have a MazdaMX5 MK3 that I’ve fitted eibach springs to and they have a weird feel that is apparently ‘par of the course’ with progressive springs….
In my experience, every modification you make to a car has a downside.
Post by: LC5F on August 24, 2021, 09:52:55 pm
B8's are just an OEM+ valving, offering slightly more resistance - they won't ruin the ride...
That is unless you have an some sort of automotive princess and pea thing going on.
After market top mounts - Project Siver stuff is good for the money, they tend to use standard sized bearings so they can be rebuilt/upgraded
Post by: brian_badonde on August 24, 2021, 10:16:22 pm
If you have a gander in the mods section of the forum, I've written a review of the b8 pro kit there. In summary, minimal sacrifice in ride comfort (if at all) but tightens everything up nicely.
Sent from my SM-G960U using Tapatalk
Post by: pudding on August 29, 2021, 02:12:16 pm
The B8s are valved differently according to vehicle model.  I've read Bilstein have backed the damping off a bit in recent years as the old B12 Sportline kit was too harsh for UK roads.  The 'Pro' kits tend to be for non-GTI/R32 models and have softer springs than Sportline.  So long as the axle weights are broadly the same as the GTI for the TSI/Diesel 'Pro' kit, you can't really go wrong.
GTIs are quite firm to begin with, so any aftermarket kit for a GTI specifically will be a good 30-40% stiffer, because the market for GTI owners wanting something the same or slightly softer than standard, and zero or minimal lowering is tiny......hence why a MK6 B12 'Pro' kit is the route to go down to achieve that.  Only the Sportline is available for the GTI, being both lower and stiffer than Pro.
As PKGTI very rightly points out, every mod comes with a compromise.  Every change is objectively measurable, it's just peoples perception of that change which is subjective......which is why there is no universal kit to please everyone. Some folk find OEM too firm, but to me it's a wobbly old blancmange pudding.
