All Things Mk5 => Mk5 General Area => Topic started by: andyiseddy02 on July 19, 2021, 07:46:32 pm
Title: Turning to build pressure following oil change but not starting.
Post by: andyiseddy02 on July 19, 2021, 07:46:32 pm
Is there any way of turning the engine over without it starting to get the oil flowing following an oil and filter change.
With an older car it would be a simple case of pulling the HT lead out of the cap.
Title: Re: Turning to build pressure following oil change but not starting.
Post by: Jb55 on July 19, 2021, 09:17:54 pm
Pull the fuel pump fuse
Post by: LC5F on July 19, 2021, 11:33:18 pm
or unclip the loom from the coil packs
Post by: rich83 on July 20, 2021, 11:26:00 am
Not sure why you would want to do that. It takes about 1-2 seconds for the pressure to build back up after a change. No big deal.
Post by: andyiseddy02 on July 20, 2021, 06:58:15 pm
Sounds like a sensible idea to me. Those couple of seconds without oil circulating puts extra wear on an already high mileage engine.
Post by: rich83 on July 21, 2021, 12:18:31 pm
Negligible.
Post by: LC5F on July 21, 2021, 02:34:47 pm
In day to day use, I agree negligible
But if the engine is freshly built or has stood for a very long while with all the oil in the sump, getting the oil pressure up before firing is has to be a good thing.
Unfortunately the detail of why the OP wants to do this has been missed out.
Post by: andyiseddy02 on July 23, 2021, 06:30:51 am
Reason?
Do I have to give a reason other than it is something I want to do.
Post by: DBXdarkangel on July 23, 2021, 03:03:56 pm
Gonna get cold in here with that attitude I reckon.   :thinking:
Post by: pudding on July 24, 2021, 01:26:53 am
There are anti-drain back check valves in the block and oil pump to make post oil change priming unnecessary.
If you want to do it though, I recommend removing the spark plugs as the engine will turn over faster and therefore build oil pressure quicker.
