All Things Mk5 => Mk5 General Area => Topic started by: Duelsy on August 02, 2021, 03:25:54 pm
Title: RCD330 - pre-programmed CANBUS
Post by: Duelsy on August 02, 2021, 03:25:54 pm
Hi all,
New owner of a MK5 Golf GTI. Picked it up Sunday. I parted way with an Audi RS4 B8, as I'm saving to buy my house. GTI seemed like a great run around, really enjoying it. :happy2:
I'm looking to upgrade to the RCD330 head unit. My car is a 56 plate, I believe I need a canbus change to avoid battery drain. I know @Pashka (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=5723) used to sell pre-programmed ones but not sure if he's active on here anymore (I've messaged him just in case). Therefore wondering if anybody else provides a similar thing?
He
Title: Re: RCD330 - pre-programmed CANBUS
Post by: mjmallia on August 03, 2021, 07:12:22 am
If you have VCDS or know someone who has, its just a case of noting all the selected modules in your current systems first (screenshots of the old canbus selections are a must here) and replicating them on the new module once it is fitted by name.
When I did mine note that the new canbus units have a longer list, which also means the module numbers will not correlate between old and new.
Post by: Stupots on August 03, 2021, 01:32:13 pm
Not just the installation list, but also the coding for each module as that is the most important part.
Post by: BPGTI on August 05, 2021, 08:42:29 am
I had one fitted at VW Retrofits in Birmingham. I think he'll ship out pre programmed ones too. https://www.vw-retrofit.co.uk
Was about £80 fitted from what I remember.
Post by: Raj2212 on August 06, 2021, 01:30:02 pm
@Pashka (https://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=5723) did mine a few years back. He also coded my mk6 flat bottom steering wheel. Rate that guy.
