All Things Mk5 => Mk5 General Area => Topic started by: frasermk5 on May 08, 2022, 01:50:24 pm
Title: Chirp Unlock
Post by: frasermk5 on May 08, 2022, 01:50:24 pm
I’ve coded the car to have a audio confirmation (beep) when locking and unlocking but it hasn’t worked, yet the alarm siren is working perfectly. Any ideas?
Title: Re: Chirp Unlock
Post by: Sebas_theFish on May 08, 2022, 01:54:59 pm
Enabled it in the MFD menu too? It adds another option called 'ATA' you may need to enable too.
Make aure the 'horn confirmation configuration blocked' option is unchecked in VCDS too otherwise this will stop you enabling it.
Sent from my Samsung Smart Fridge
Post by: frasermk5 on May 08, 2022, 02:11:08 pm
Oh I haven’t thought to check, I will have a look! Where would I be looking?
Post by: Sebas_theFish on May 08, 2022, 02:16:07 pm
Under 'Convenience' in the MFD menus and the VCDS setting is with the various others to enable the alarm chirp.
Post by: frasermk5 on May 08, 2022, 03:14:51 pm
In that case, I don’t have the full MFD so have no option to access settings, convenience etc.
