All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Sebas_theFish on May 22, 2022, 12:22:53 pm
Does anyone know the pinout of this main 20 pin plug in the door. I'm particularly interested in which of the wires here are responsible for the car being able to 'see' when the door is open and closed as I'm trying to workout a difference between Mk5 and Mk6 door controllers.
Essentially when I switched to a Mk6 module, literally everything worked except the door wouldn't lock properly and threw code 00929 - Locking Module for Central Locking; Front Passenger Side (F221). Switched back to the Mk5 module and it works fine, physical pins on both modules are identical, the Mk6 module must be faulty as I can't see the only difference between them being wiring for the locking mechanism.
(https://i.postimg.cc/RhcSm71Y/20220522-181318.jpg) (https://postimg.cc/0KyRdJBG)
