All Things Mk5 => Mk5 General Area => Topic started by: shail on September 13, 2022, 08:25:33 pm
Title: Crazy quote for brake dust sheilds?
Post by: shail on September 13, 2022, 08:25:33 pm
I was just quoted £430 to replace both rear brake dust shields.  Quoted 4 hours labour.  I'm thinking it's way off the mark.
I was expecting it to be around £100 -£120
It's a local garage who up until now have seemed to offer good value.
Title: Re: Crazy quote for brake dust sheilds?
Post by: rich83 on September 13, 2022, 08:51:13 pm
Fairly big job as not only the brakes have to come off but also the hubs have to come off too.
Post by: Clarkj93 on September 13, 2022, 09:40:38 pm
If they're rusted and rattling sometimes you can just about cut them off with tin snips. That's what happened to mine anyway. If you can get away with that I wouldn't bother replacing them unless you're going off roading, I don't run any with zero issues even in bad uk weather.
I didnt think the hubs had to come off but I have not had do much more than the rear shocks and pads on the rear so happy to be proven wrong.
Post by: shail on September 13, 2022, 09:58:20 pm
They are rusted and one is rattling.  I'm going to have a look at the weekend to see if I can cut them out and not replace if I can do it without taking hub off..  Spending that much money on them just isn't on top of my list!
I am having flashbacks to the total ball ache removing the caliper carrier is. I swore blondnid never attempt that ever again!
Post by: Clarkj93 on September 13, 2022, 10:17:18 pm
Yeah at a price that steep you may aswell do the discs at the same time since the caliper carriers are a bitch to get off anyway to replace them.
Post by: shail on September 13, 2022, 10:31:58 pm
I did the rear pads and discs about 25k ago, so they are still in good shape (unfortunately!!)
Post by: terrier on September 14, 2022, 06:48:46 am
The rears can be cut to fit NO need for all that work  I have RIDEX ones fitted  ebay search for FEBI ones You will need 3 new fixing bolts too
Post by: pudding on September 14, 2022, 08:26:43 am
Wait until you need a rear bearing, or a brake job.  Some people cut out the thin section of the new shield across the 2 lower bolts, which will negate the need to remove the hub, but it may make it floppy like a slice of Tesco basics ham.
It's not that big a job anyhoo. Removing the bearing hub is a piece of soft and squishy cake. It's one bolt  :grin:  The only biatch bit is the caliper carrier bolts, but even that is just a matter of having the right tools and experience.
Post by: shail on September 14, 2022, 09:12:23 am
I've now ordered some off eBay and some new bolts. Going for the cutting method for now and leaving the hub where it is.
Post by: terrier on September 14, 2022, 02:12:53 pm
Paint any bare metal to combat rust (Im sure you have enough rust to tackle) :grin:
Post by: mjmallia on September 14, 2022, 02:36:37 pm
I cut the thin section out the middle of the shield, to then slot it over and bolt down..........similar to what the fronts are like.  No issue at all
Post by: LC5F on September 15, 2022, 10:15:44 pm
Very likely the shield will just pull off or twist off
If your doing it properly, getting the brake carriers off that's the hardest part. the rest is straight forward
If you like stone guards there are Galvanised ones out there - IIRC the bolts holding them on are M5 - use stainless bolts.
Post by: shail on September 16, 2022, 02:52:46 am
I am hoping they just pull off.  I have bought new shields and bolts, although I've got M6.  I'll attempt the to take carrier off.  Last time I ended up buying a swivel head ratchet which helped with access and leverage.
Post by: probedb on September 16, 2022, 02:56:11 pm
Jayzuz! It cost me £50 for one side with me supplying the shield and bolts.
Post by: pudding on September 16, 2022, 05:33:09 pm
Aye, silly price isn't. Similar to the chap on here getting quoted £420 to fit a carbon can. A mate told me the other day he was quoted £450 to fit springs to his M135i, and it's just as easy to do as a MK5. It seems local garages are getting a tad greedy.
But yeah, I paid about £35 each for the shields from the dealer.
Post by: chowgar on September 25, 2022, 11:28:50 pm
Fronts don’t need the hubs coming off but disc will the rears will or cut them to fit around
Post by: chigmuss on October 01, 2022, 03:17:01 pm
Rub back and paint obvious rust and sandwich some massive washers over the holes that have rusted out and bolt them back down again
Post by: shail on October 01, 2022, 06:00:00 pm
Started this today.  Didn't get far as I couldn't find my stubby triple square M14 socket, but found the longer one which I know is too long.  Lost all my patience within 2 mins of not finding the socket and then attacked it with a Dremel, which wasn't really successful.
Going to go at it with some tin snips tomorrow - it's so rusted it's flapping about so think I can get in there with some snips.  Basically going for a bodge!
Post by: probedb on October 02, 2022, 09:21:16 am
If you're just removing, tin snips will work fine, that's how I got both of mine off  :grin:
Post by: shail on October 02, 2022, 09:52:22 am
Yes, just removing them for now.  Need to buy some tin snips though!
  Would these be man enough? https://www.screwfix.com/p/aviation-tin-snips-set-3-pack/2941v
Post by: pandaman on October 02, 2022, 10:06:50 pm
Had the same problem, rusted through all screw holes and hit a pot hole thing was completely loose and rattling around. Used tin snips too, mine looked like these
https://www.toolstation.com/irwin-gilbow-general-purpose-snips/p60793 (https://www.toolstation.com/irwin-gilbow-general-purpose-snips/p60793)
Still haven't replaced them, have new ones waiting, I'm thinking I will put them on when I next do discs and pads. Really can't be assed with taking the hubs off so I will cut and paint the new ones
Post by: shail on October 03, 2022, 07:37:12 am
All done.  I bought the 3 pack of snips and they worked well.  No more rattling.Thanks all for your help.
