		All Things Mk5 => Mk5 General Area => Topic started by: fsgti on September 23, 2022, 12:16:04 am
				This has been lieing around in my engine bay not connected to anything for a while now.
 Anyone know what it's for and/or where it should be connected?
 Many Thanks
 (https://i.postimg.cc/pdW49zww/Loose-wire.jpg) (https://postimg.cc/VJhDprLg)
				I assume you have a turbo, and can only think it is a line that was used for a gauge.
 Agree with this. There is a grommet which lets you thread the pipe into the cabin behind the dash on the passenger side.
 Yup the car does have a turbo. Maybe one of the previous owners used it for a gauge. Would this cause a boost leak of some sort if I leave it loose?
				Block the end at least, screw bolt etc
 Thanks will do
				I bet if you trace it back into the car it will go nowhere.
 Curious to see, I'll have to check it out soon.
