All Things Mk5 => Mk5 General Area => Topic started by: MK5GTIinside on October 24, 2022, 08:14:08 pm
Title: Boost loss / noise when losing boost
Post by: MK5GTIinside on October 24, 2022, 08:14:08 pm
So recently my MK5 GTI 05 when i give it some it will start to hesitates could range from 40mph upto 80mph- a noise like a screaming cat stuck in the bonnet and loss of boost for a few seconds then comes back on boost the noise appears when it hesitates and doesn't boost for a few seconds anyone any ideas?
Title: Re: Boost loss / noise when losing boost
Post by: Clarkj93 on October 26, 2022, 12:15:36 pm
Some possibilities that come to mind:
Diverter Valve - very common boost leak point for these engines, it's happened to most of us
Rocker cover gasket - less common but can be the cause, if it's really oily by the rocker cover seal then could be this
Post by: mjmallia on October 26, 2022, 12:24:40 pm
A split DV will make a louder than normal pssssst! noise, almost like a blow off valve.......no boost all the time, or at least very little with the car driving like a NA 2.0
Screaming or screeching......sounds like a turbo issue to me.....the blades hitting the walls of the housing.
Post by: Fallout-NL on October 26, 2022, 04:17:38 pm
Is the wastegate actuator ever known to cause issues like this on Mk5 GTI's?
I've recently replaced my DV, which improved the boost situation, but there's still times where I suspect I'm losing boost somewhere. Especially if I start accelerating from lower in the rev range, or at least, it seems that way.
Post by: MK5GTIinside on October 30, 2022, 03:30:22 pm
Ye it sounds more like a screaming / screeching noise like you mentioned. more than any pssssst noise. may have to get it into a garage asap
