All Things Mk5 => Mk5 General Area => Topic started by: davidjonknight on January 24, 2023, 09:41:40 pm
sorry to bother you all. i have an 06 Mk5 golf gti. i seem to of lost the bolt that secures the air filter induction kit to the engine. it secures through a plate on the engine.
anyone any ideas where I can get a replacement ?
It would be from the supplier of the filter or find one yourself.
The mounting point I assume is the one on top of the vacuum pump.......this is usually just a hole on a standard setup.
Not my car, but it is the upper hole on the oval plate.......image of a standard setup
(https://blog.fcpeuro.com/hs-fs/hubfs/Images/Blog/active/Humble-Mechanic-Brake-Vacuum-Pump/05-hm-bvp-booster-hose.jpg?width=1400&name=05-hm-bvp-booster-hose.jpg)
