		All Things Mk5 => Mk5 General Area => Topic started by: K03MK5 on February 08, 2023, 05:42:39 pm
				Any ideas on fixes for the fault codes below?
 Steering wheel:
 00576 - Terminal 15
 00883 - Ignition starter switch (clamp S)
 00884 - Ignition starter switch (clamp X)
 01744 - Ignition/starter Switch (D) (Terminal P)
 00885 - Ignition starter switch (clamp 50)
 Radio:
 00849 - S-contact at Ignition / Starter Switch (D)
 00856 - Radio Antenna
 00821 - Antenna 2 for Radio (R93)
 Central electronics:
 02390 - Control/regulation for ambience lighting (E400)
 Thanks.
				First few are related to replacing the ignition switch.
 tip - Google the numeric code and add ross tech wiki
 I'm pretty sure the ambient lighting one is generated when you have a faulty door lock
				Yep guessed that.  Hoping I won’t need to replay the ignition switch.
				I had the ignition switch codes about a year ago and decided to replace it before it went and i couldn't start the car. Replaced it and still have the first two codes in your post above...
