All Things Mk5 => How to Guides / Troubleshooting => Topic started by: blingsta on March 13, 2023, 01:25:30 am
hi all
i want to do a coolant flush... whats best way? - rad bottom hose or the aux water pump near the sump?
https://www.myfastgti.com/threads/coolant-flush-diy.17420/
would the aux water pump be ok to flush from?
Can't see a problem doing it from aux pump
Would that empty the whole system? Is it the same as doing it from rad bottom hose?
It's as low a point in the coolant system so can't see a problem in doing it from there - probably easier than getting the bottom hose off.
Yes it is :signLOL:
i'll try it and see what happens :happy2:
thanks for reply
Just a quick update .
i managed to flush the cooling system from the lowest part - (aux pump) which was sooooo much easier than getting that rad bottom hose off !! :partywave:
anyways.. all flushed n cleeeean now :jumpmove:
Hey ! Just done a coolant change on mk5 1.9 tdi, undone the bottom rad hose and maybe 2/3 litres off old coolant came out , I was expecting 8 litres ? I’m guessing that’s not a complete flush then and the remaining 5 ish litres would be sitting in the engine??? Any help would be much appreciated
