		All Things Mk5 => Mk5 General Area => Topic started by: Jabethell on December 18, 2023, 03:45:45 pm
				Hello
 Mk5 GTI golf BWA engine.
 So I’m getting a EPC light and EML. I’ve replaced the spark plugs, coil packs, HPFP, cam follower, HPFP plug and the N80 plurge valve. After replacing the parts the car did work but only for about 5 minutes and it went back to running really rough with the EPC and EML. I’m currently getting the following codes:
 P0659 - actuator supply
 P0458 - evap
 P2295 - fuel pressure regulator 2
 P0031 - H02s heater control
 P2293 - fuel pressure regulator 2 performance
 Most garage I’ve called can’t do anything and my nearest VW specialist is booked up until mid Jan. It’s worth noting that the issue has gotten worse to the point where it can’t be driven. I’m at my wits end! Any help will be really appreciated
