All Things Mk5 => Mk5 General Area => Topic started by: GTI 500 on January 25, 2024, 07:50:48 am
I have retrofitted factory Xenons to my 2005 Mk5 Gti,
There all coded & working, But can they be coded to use the manual adjuster or will they only work with the factory level sensor?
They can be used without the auto levelling as it's a seperate module that needs to be installed and coded anyway.
Does that mean they can be adjusted using the level switch for the original head lights??
