All Things Mk5 => Mk5 General Area => Topic started by: chronos1213 on May 02, 2024, 04:04:39 pm
Hi,
Any ideas as to what this noise could be? Clicks when setting off and coming to a stop, sometimes clunks.
Had it since my front suspension was replaced? Wishbones, control arms, tie rod ends, shocks top mounts replaced.
They said they had to adjust the front subframe so maybe the bolts?
Get it seen to by a vw specialist Does sound like subframe knocking All the bolts will need to be replaced and torqued properly
There are aftermarket kits which will fix it if installed properly :happy2:
Yeah if it's not crunchy dried out inner CV joints, it will be subframe movement.
